gas in crank case?? please help!!
  • steveo_4192003
  • Topic Author
  • 77kz650b-1
02 Jul 2006 00:03 #58642 by steveo_4192003
gas in crank case?? please help!! was created by steveo_4192003
my bike flooded out and wont sart. i left pet-cock on all night, so i decided to re-set floats and do the oil change while i was at it! i pulled the drain-plug and oil was watered down with gas!! it was not very thick and ran out pretty quick
i did set floats, so this wont happen agian!!!
they were WAY out, and it ran good but fouled out 2 sets of plugs in 1 week
all that gas that flooded my bike, went past the rings and in the crank case. it was hard to kick over and didnt want to start. i did get a few big back-fires through the tail pipes!
should i be able to keep pet-cock on all night and not flood my bike??
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
02 Jul 2006 01:01 #58647 by steell
Replied by steell on topic gas in crank case?? please help!!
If everything works perfectly, then yes you should be able to leave the petcock on all the time.
But, do you really want to take the chance?
  • ambergrismooon
  • Visitor
02 Jul 2006 04:53 #58664 by ambergrismooon
Replied by ambergrismooon on topic gas in crank case?? please help!!
This should install the mindset that you really should turn the spigot off when parking the beast! The world is not perfect and just when you think it is.....BLAMO!
Post edited by: ambergrismooon, at: 2006/07/02 07:53
  • KZ_Rage
  • Kentucky Bourbon Barrel Ale
02 Jul 2006 07:35 #58689 by KZ_Rage
Replied by KZ_Rage on topic gas in crank case?? please help!!
Your needles or seats are probably worn or dirty. You would be probably do yourself a favor and rebuild the carbs. Buy the kits, but only replace what you have too. I have been told that the mains and pilot jets in some kits are suspect. Clean the carbs in a good carb cleaner solution, you can use plain white vinegar to finish the clean up and the brass parts will look new. Don't leave them in the vinegar too long, just long enough to clean them to near new.
While you're doing that, take the tank off and clean it out too. Check for rust, rust residue can get inbetween the needle or block a jet or passageway in the carb. Replace you hoses too if they are old, it is a cheap insurance to take at this time. If you can fit one in, put an inline fuel filter from one of your local car parts stores. Get the smallest one you can, stay away from the glass ones though. There are several old articles here on cleaning the tank if you find rust in there. Don't forget to take your finger and wipe the top of the inside of the tank near the filler hole. See if you get rust on your finger or if it feels rough and pitted. Tanks rust above where the gas is, that is why it is important to store a bike with a full tank of gas for winter as it won't rust where the gas touches it.
What type of petcock do you have? Is it "On", "Off" & "Res"? If it isn't you have vacuum controlled type and the diaphragm or other parts are bad. (sorry didn't note what your bike has for a stock petcock).
Keep us posted.
Post edited by: KZ_Rage, at: 2006/07/02 10:41
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
02 Jul 2006 09:28 #58704 by baldtires
Replied by baldtires on topic gas in crank case?? please help!!
I’am not familiar with these particular carbs but it seems there should be a overflow on them
  • wireman
  • Visitor
02 Jul 2006 11:56 #58730 by wireman
Replied by wireman on topic gas in crank case?? please help!!
with the price of gas these days id save the gas/oil you drained out and use it to run the chainsaw!:P
