Kz750H exhaust on Kz750e
- edhead74
08 May 2013 19:35 #586403
by edhead74
Es
Kz750H exhaust on Kz750e was created by edhead74
My exhaust on my 81 Kz750E has had the baffles ripped out from the PO. And looking for a complete set. Wondering if any on has tried the exhaust form a 81 750H (kz 650D/H/E) on a 750E? Wondering about head mounts and centerstand.
Es
- Thank you received: 1656
08 May 2013 20:24 - 09 May 2013 10:14 #586409
by martin_csr
Replied by martin_csr on topic Kz750H exhaust on Kz750e
My guess is that it will work. I put a 750E exhaust system on my 650-CSR which has the same frame as the 750H-Ltd. The engines are basically the same & the center stand recess lines up. So I'd guess the fitment would work in the other direction. I had to use the E muffler brackets, so you'll probably need the brackets from the Ltd.
Last edit: 09 May 2013 10:14 by martin_csr.
The following user(s) said Thank You: edhead74
