kz1000 shifting question
- terrys4170
07 May 2013 22:47 #586228
by terrys4170
kz1000 shifting question was created by terrys4170
I am currently reassembling a 1980 kz1000 engine. I have assembled the cases and installed the shift forks, I can shift it into 1st gear and back to neutral, but can't shift into 2nd or higher. the left shift fork won't slide over far enough for the other gears to engage. Is this normal while sitting, or is something wrong? The manual tells me to shift through all the gears, but it is not happening.
- DFIGPZ
- Thank you received: 122
07 May 2013 22:58 #586230
by DFIGPZ
The following user(s) said Thank You: terrys4170
- terrys4170
07 May 2013 23:24 #586232
by terrys4170
Replied by terrys4170 on topic kz1000 shifting question
what prevents the gear from sliding over far enough while not moving?
- Thank you received: 2829
07 May 2013 23:47 #586238
by 650ed
Replied by 650ed on topic kz1000 shifting question
There are 3 little steel balls on the output shaft that are part of the shift lockout mechanism. If you take a look at the "Transmission" parts diagram on Kawasaki.com you will see them. I believe the lockout gizmo was put on in 1978; my 1977 KZ650 doesn't have it but later models do. Ed
- terrys4170
07 May 2013 23:51 #586239
by terrys4170
do they move or slide when the trans is rotating?
07 May 2013 23:55 #586241
by 650ed
I believe they move out from the shaft via centrifugal force when the shaft is turning. That's the output shaft, so when it's turning the counter sprocket is turning which implies the bike is moving. Ed
- terrys4170
08 May 2013 00:03 #586243
by terrys4170
Thanks Ed. I was about to brake the cases open again and inspect the transmission. I see the 3 steel ballsin the manual, although they don't tell you how they operate or what they do. I did not brake down the transmission so I did not look at them directly, I simply pulled it out and put it back in. I don't want to get it all back together, start it up and find I have a problem shifting. This helps to put my mind to rest. I appreciate the help.
