Valve cover switch
- Darkangel
07 May 2013 14:08 #586159
by Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
Valve cover switch was created by Darkangel
For those of you who have done the valve cover swap from US to Candian Model to get rid of the reeds, did you experaince a difference in performance?
Is the swap straight, are there anythings that one should be aware of?
- Dr. Gamma
- Thank you received: 680
07 May 2013 20:21 - 07 May 2013 20:25 #586213
by Dr. Gamma
1986 RG500G 2 stroke terror.
Replied by Dr. Gamma on topic Valve cover switch
I know on the 1981 and up KZ1000 heads you will still have to block off those tiny little ports that goes from the exhaust port up along the head to where it meets the valve cover. Without blocking off those ports and fitting a Canadian model valve cover. I don't think the valve cover gaskit would last too long before it blew out.
When using the Canadian model valve covers, I always filled in those little ports. The Canadian cylinder heads have that boss cast into them, but they do not have that port drilled through them. The non-reed valve covers do look some much cleaner and nicer!!! My KZ1000S1 used the Canadian model valve cover. I ordered a few of them back then for a few friends of mine.
Last edit: 07 May 2013 20:25 by Dr. Gamma.
- loudhvx
- Thank you received: 1616
08 May 2013 00:35 #586250
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Valve cover switch
I don't think the gasket will blow out. It won't have anymore pressure there (it's usually vacuum) than an emissions valve cover with the reeds blocked off. The gasket is the same for either.
1981 KZ550 D1 gpz.
Other links.
- Powerstroke_fan
- Thank you received: 83
08 May 2013 08:12 #586280
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Valve cover switch
The valve covers arent exactly the same they have the little pieces sticking out for the emmissions. But it could probably be used or modified.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Darkangel
10 May 2013 01:44 #586675
by Darkangel
Replied by Darkangel on topic Valve cover switch
well this is a kz 650 b2 model and i have found a valve cover that will work on it, and it would like to use it. I have already gotten rid of all of the other stock air crap, and i just want to eleminate any other issues that i may have with those reeds.
- kawsakiman
12 May 2013 13:28 #587024
by kawsakiman
Replied by kawsakiman on topic Valve cover switch
direct swap, no mods needed. no real performance gain or loss. I do it to all my bikes because the smog covers look so damn ugly.
they are just getting harder to come by. last one I bought for a j head was rough and cost me $80.
