- Thank you received: 3
kz1100 cams
- gdprather
06 May 2013 14:56 #585992
by gdprather
1985 Kawasaki Vucan vn700A1
1983 Kawasaki KZ1100D2 Spectre
kz1100 cams was created by gdprather
I am looking for a drop in hotter cam for my 1983 spectre 1100. Can anyone point me in the right direction please?
- Mcdroid
- Gone Kwackers
- Thank you received: 317
06 May 2013 15:12 #585994
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic kz1100 cams
1983/1984 ZX1100-A1/2 (aka GPz1100) should be a drop in and they are definitely hotter. Be advised, if you find these on eBay, you'll be bidding against me :laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Motor Head
- Thank you received: 391
06 May 2013 15:51 #585997
by Motor Head
Replied by Motor Head on topic kz1100 cams
If still using the BS34 Cv Carb, you may find the loss in Vacuum signal causing poor running, even with jetting changes. You would be better switching to a Manual slide, like the Cr's or RS's
- havakaw
- Thank you received: 27
06 May 2013 21:06 #586042
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Replied by havakaw on topic kz1100 cams
Unless you are going to change the cam chain also,don't do it.I got a NOS set of ELR cams from an 81-82 GPZ,81-83 1000J motor.Definately larger than stock.But the overlap is so tight,that the valve clash if they are not perfectly aligned and the cam chain is tight.Just ride it.
'80 KZ 750 LTD-H
- gdprather
07 May 2013 00:38 #586105
by gdprather
Replied by gdprather on topic kz1100 cams
Well maybe I will wait until a rebuild. I was just hoping I could drop some cams in and set the timing. Thanks for the info guys.
