Kz1000 bottom end and a kz900 head
  • lttletodd
  • lttletodd's Avatar Topic Author
05 May 2013 22:39
#585867
Ok guys heres my issue. I have a kz1000 bottom end pistons and cylinders. But i have a kz900 head. Will the exhaust collars off a 1000kz1000 work and is there a difference between the years? Im putting 8mm studs in it.
Oh god... why are there extra parts left over....
  • wireman
  • wireman's Avatar
Re: Kz1000 bottom end and a kz900 head
05 May 2013 22:44
#585869
As long as its a 77-78 bottem end it will drop right on,if its a 79-80 bottem end youll need to use the cam sprockets off the 1000 camshafts depending on what crankshaft it has. :)
  • MFolks
  • MFolks's Avatar
05 May 2013 23:28
#585881
The Z1 and Kz900/early Kz1000 had M6 X 1 studs for the exhaust system. On the "J" engines, Kawasaki went to M8 X 1.25 studs.
  • Dr. Gamma
  • Dr. Gamma's Avatar
05 May 2013 23:36
#585885
MFolks wrote: The Z1 and Kz900/early Kz1000 had M6 X 1 studs for the exhaust system. On the "J" engines, Kawasaki went to M8 X 1.25 studs.
The 1977 KZ1000A1, and the KZ1000B1 both had 8mm exhaust studs. Only the Z1/KZ900 heads had the little 6mm exhaust studs.
Thats the way everybody spots a 900 head from a 1000 head.
1986 RG500G 2 stroke terror.
  • wireman
  • wireman's Avatar
06 May 2013 00:22 - 06 May 2013 00:28
#585896
you can use the the newer collars on the smaller studs in a pinch with some flat washers :)
Last edit: 06 May 2013 00:28 by wireman.
  • lttletodd
06 May 2013 00:30
#585898
I appreciate the info everyone! She's been a very long project. And she's almost done. Hopefully should be up and running by next weekend!
  • lttletodd
06 May 2013 00:31
#585899
What dimensions are different between the newer style the older style collars?
  • wireman
  • wireman's Avatar
06 May 2013 01:39
#585906
The collars are physically the same 73-80 900/1000,only difference being 8mm holes starting on 77 kz1000 versus 6mm for 73-75 z1 900 and 76 kz900 and im guessing the early 77 900s used 6mm studs also. :)
  • LarryC
  • LarryC's Avatar
06 May 2013 07:17
#585930
J model collars will fit and look a lot nicer IMO.
Larry C.
