  • Page:
  • 1
  • 2
Poll: opinions on cam end plugs which one to use (was ended 0000-00-00 00:00:00)
polished aluminum
3 17.6%
black oem style
8 47.1%
APE aluminum
6 35.3%
Total number of voters: 17 ( GPz550D1, roy-b-boy-b, DuaneBallard, dbc92s10, richard_oxon ) See more
Only registered users can participate to this poll
Cam end plug opinions 05 May 2013 18:23 #585818
  • ramtough_63
  • ramtough_63's Avatar Topic Author
  • Thank you received: 132
getting ready to order cam end plugs just wanted some opiions on what most people prefer too
see and any comments on the aluminum vs the plastic/rubber whats are your thoughts
my cam cover end are semi polished (quick polish job going to have a valve cover chromed)
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Cam end plug opinions 05 May 2013 18:47 #585824
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
  • Thank you received: 83
I personally have the polished aluminum but id say it all depends on how the motor looks. But either way i would buy aluminum.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Cam end plug opinions 05 May 2013 19:08 #585828
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1485
Buy Once, Buy aluminium.
You can get black anodised ones if you want them to blend in and look like the original rubber items.
Cam end plug opinions 05 May 2013 22:08 #585862
  • Dr. Gamma
  • Dr. Gamma's Avatar
  • Thank you received: 664
I always used the OEM rubber ones installed with the little lip toward the inside of the head.
I never had one leak when installed in that reverse direction.
Plus that little splash of gold inside of them looked real good on the grey of my GunKoted motors!!
1986 RG500G 2 stroke terror.
Last edit: by Dr. Gamma.
Cam end plug opinions 05 May 2013 22:08 #585861
  • Dr. Gamma
Sorry, computer F/U. Hit SUBMIT key four times, sorry again!!
Cam end plug opinions 05 May 2013 22:08 #585860
  • Dr. Gamma
Cam end plug opinions 05 May 2013 22:08 #585859
  • Dr. Gamma
Sorry computer F/U!!!!
Cam end plug opinions 06 May 2013 11:30 #585974
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
i'm in the once and done aluminum camp.
Cam end plug opinions 06 May 2013 11:53 #585978
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1994
Bought once and installed 35 years ago . Never any problems. Especially with high power motors or boosted motors with higher crankcase pressures.
GO ALUMINUM. Cheap investment
Dave B) B) B) B)
Cam end plug opinions 06 May 2013 12:13 #585980
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Thank you received: 181
The billet aluminum cam-end plugs can work well. However, they can be a problem on a few heads - most noticeably the earlier Z1 heads. Ideally the line boring for the cams would be a perfect intersection of the head and cam caps - but what you find is variations up and down on the machining - to the tune of over 20 thou on some heads. This means the cam-end plugs can sit high or low on these heads. If they sit high, the only thing you can do is remove a little metal from the upper surface of the billet aluminum. If they sit low, you have to put a thin bead of gasket goo to help seal them.
When I first bought my 1973 turbocharged z1, the bike came with RC Engineering billet cam-end plugs - and they sat high and leaked oil from that area. At first I thought they were just poorly made, but when they were installed in a kz1000 head, they fit perfectly. I checked 10+ heads in my garage, and was very surprised on the depth difference from head to head.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Cam end plug opinions 06 May 2013 19:05 #586032
  • Garn
  • Garn's Avatar
I like the alloy plugs (anodized black not blue).
There has always been two schools of thought, as regards to the sealing of these alloy cam-end plugs. One is to seal the circular part with part of an appropriate sized round section of an O-ring. The other, is to fill the vee groove with a sealing compound.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Last edit: by Garn.
Cam end plug opinions 06 May 2013 20:12 #586035
  • turboking
  • turboking's Avatar
  • Thank you received: 106
I've turned oem rubber cam plugs with the lip inside the head and used the billet aluminum plugs......both work :huh: I think the inverted oem plugs give a road race look to the engine........ :dry:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • Page:
  • 1
  • 2
