Carb Issues
- Brian.Wolf
Carb Issues
05 May 2013 12:32
I have a 1981 kz750 not sure what model but it has kz1000 carbs on it and im not sure how to adjust them. Its running rough and idling high. Someone told me they pressed caps over the pilot screw adjustment. Is this true. if so how do i get it out ? please help
- jonarmstrong
Re: Carb Issues
05 May 2013 12:45
Drill a hole in it and pry it out w a small screwdriver. Go slow and easy. The screws are brass and you don't want to be cutting on them.
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- Brian.Wolf
Re: Carb Issues
05 May 2013 12:47
okay thanks. and it should be located on the top of the carb right. i dont want to drill into something im not suppose to
- jonarmstrong
Re: Carb Issues
05 May 2013 12:59 - 05 May 2013 13:02If its the cv carb, its right beside the vacuum port
Last edit: 05 May 2013 13:02 by jonarmstrong.
- Matteson
Re: Carb Issues
05 May 2013 13:04
There are several models of kz1000 carbs. Pictures would really help.
KZ 900-a4
