Stripped threads on oil plug (1980 KZ750)
- Kawasaki_Mike
- 1980 Kawasaki 750 LTD
- Motor Head
- Thank you received: 391
Worst case, pull the pan off, and then repair the threads, or replace the pan with a good used one.
- JR
- Thank you received: 448
Kawasaki.com, owner info, motorcycle etc etc says that oil drain plug is 12 x 15 and you should be able to get an oversize one off the shelf at Canadian Tire or an auto parts store. I got a temporary one like in the pic from Canadian Tire and while it worked I really didn't have confidence in it and it seemed I needed to check and tighten every few days.
Good luck.
- Motor Head
JR wrote: I had a similar problem a number of years back and like Motor Head said you are on the right track with the vise grips. Just make sure you are turning in the right direction.
Good luck.
That would be in an Emergency Only, and would be to get somewhere for a repair, or home. Expecting it to leak some.
- JR
"That would be in an Emergency Only, and would be to get somewhere for a repair, or home. Expecting it to leak some"
It kept me going until I got a replacement oil pan. The drain plug that was in there was already oversize
- Thank you received: 1656
If the oil pan is stripped, you could replace it. There are plenty listed on ebbaayy. I would ask the sellers to verify that the drain plug & oil pan threads are good. Your bike has the same oil pan as all KZ650s & most KZ750-4s up to 1983.
- Kawasaki_Mike
- Kawasaki_Mike
Attachment KZ_750.JPG not found
- Kawasaki_Mike
Attachment B-6.png not found
