bogs when clutch let out
  • Old Man Rock
  • Old Man Rock's Avatar
Re: bogs when clutch let out
30 Apr 2013 08:55 - 30 Apr 2013 09:12
#584879
Ran into this exact (100%) same situation working on a friends police special....
Not sure yours is configured the same... :blush:
Clutch perch had a micro switch!!!!
Look at your left handle bar clutch perch, see a 2 conductor sleeved cable assembly going to the bottom side of the clutch lever assembly/housing...?
Works the same principle as the side kick stand switch....
Anyhoot, just a thought, worth confirming...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 30 Apr 2013 09:12 by Old Man Rock.
  • joe**
  • joe**'s Avatar Topic Author
30 Apr 2013 09:51
#584892
thanks, I'll get out the multimeter and check
'82 kz 750N
  • Motor Head
  • Motor Head's Avatar
30 Apr 2013 10:21
#584896
joe** wrote: You ask the hard questions. It was a cold blooded beast. Other than a chirp when I let off the starter button it ran fine - one hundred on all four on a compression test. Then It died when warm. Pickup coil was five ohms out of spec on the front pickup when hot. Now it won't start consistently and it boggs...
So you still have a pickup coil that is reading 5 ohms out? If so you may be losing 2 cylinders. One pickup coil runs 1 ignition coil, which fires 2 plugs.
  • joe**
11 May 2013 03:15
#586820
issue apparently solved with different pickup coils.
'82 kz 750N
