bogs when clutch let out
  • joe**
  • joe**'s Avatar Topic Author
29 Apr 2013 23:14
#584782
I've been cleaning electrical connections. If it starts, it revs fine, I put it in gear and no amount of reving will keep it from dying as I let out the clutch.
'82 kz 750N
  • Motor Head
  • Motor Head's Avatar
Re: bogs when clutch let out
29 Apr 2013 23:17 - 29 Apr 2013 23:20
#584783
Sounds like a defective side stand switch.
There is a wiring diagram in "File Base"
www.kzrider.com/filebase/cat_view/102-19...5-kawasaki-kz-750-n1
Last edit: 29 Apr 2013 23:20 by Motor Head.
  • baldy110
  • baldy110's Avatar
29 Apr 2013 23:28
#584792
What Motor Head said.
  • joe**
29 Apr 2013 23:34
#584797
this machine has no sidestand switch
'82 kz 750N
  • boatdrinks
  • boatdrinks's Avatar
29 Apr 2013 23:36
#584798
Does it roll freely in gear with the clutch in? If not you may have a stuck clutch.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
  • joe**
29 Apr 2013 23:39
#584801
it rolls freely
'82 kz 750N
  • Motor Head
30 Apr 2013 00:22
#584811
sorry I thought side stand switch from the posted symptom.
Can you link a video of how it runs then what it does when you try to take off?
  • joe**
30 Apr 2013 00:57
#584827
sorry no video capabilities. I replaced the timing advancer according to the manual, perhaps it was on wrong when it was working. What are the symptoms of the wrong orientation of the timing advancer?
'82 kz 750N
  • Motor Head
30 Apr 2013 01:05
#584832
You got a different/ new part? Or you just removed then re-installed?
  • joe**
30 Apr 2013 01:15
#584835
removed, cleaned, lubed
'82 kz 750N
  • Motor Head
30 Apr 2013 01:24
#584837
If you put it on wrong it won't run, just backfire. As long as the index pin is there, it should be on right if it runs. You could verify timing with a light though, couldn't hurt for sure.
How did it run before?
  • joe**
30 Apr 2013 01:39
#584841
You ask the hard questions. It was a cold blooded beast. Other than a chirp when I let off the starter button it ran fine - one hundred on all four on a compression test. Then It died when warm. Pickup coil was five ohms out of spec on the front pickup when hot. Now it won't start consistently and it boggs...
'82 kz 750N
