650 exhaust on a 750?
- geohaydook1
29 Apr 2013 11:56
Will the exhaust from an SR650 fit my 750e? I haven't decided what exhaust to put on this boat anchor project (that is waaay down the road) but I like the "bag of snakes" and the shorter mufflers on the SR650 and my stock exhaust is rusty and crusty. Just wondering. Thanks.
1980 KZ750e
1981 KZ650 csr (fate undecided)
Re: 650 exhaust on a 750?
29 Apr 2013 12:16 - 30 Apr 2013 10:04
They should bolt up to the head & you may have to fab up some muffler brackets, but center stand clearance may be an issue. The 750-4 mufflers have a recess for the stand, so I'd guess the center stand will bang the 650 pipes?
You'll need the half-moon exhaust collars from the 650.
A better fit might be KZ750-Ltd-4 or KZ650-CSR (the Ltd & CSR mufflers are the same). I put the exhaust system from a 750E onto my CSR - they were a direct bolt-on. The 650-CSR left side muffler has the center stand recess in the same spot. The half-moons are the same. I had to use the muffler brackets from the E, as the muffler angle is different. So you may need the muffler brackets from the Ltd or CSR.
Last edit: 30 Apr 2013 10:04 by martin_csr.
- Nebr_Rex
29 Apr 2013 18:39martin_csr wrote: They should bolt up to the head & you'll have to fab up some muffler brackets, but center stand clearance may be an issue. The 750-4 mufflers have a recess for the stand, so I'd guess the center stand will bang the 650 pipes. You'll need the half-moon exhaust collars from the 650. ]
Absolutely correct.
Some of the 650 pipes are larger in diameter than 750s between the head pipes and mufflers.
When I installed SR pipes on my '81E I had to cut and reweld as per what was posted by Martin.
I also removed the baffling and tucked them in closer to the frame for more clearence.
Which with the help of a jet kit still does'nt run quite right.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Mullineaux
29 Apr 2013 20:02
I have MAC 4-2 pipes on my bike that were originally on a KZ750 Spectre, bolted right on but the they bump out from the frame far enough that highway bars won't mount to the bike. That and I had to pull the center stand. When I was looking up the info on the MAC exhaust pre-purchase I noticed that it was one part number for all 650's and 750-4's. The brackets lined up pretty nicely too, didn't have to fab anything.
KZ650 ( '77 Engine, '78 frame, 80's ignition, MAC 4-2 exhaust, Pods, lowered [links])
1980 XS1100 full Vetter dresser
- geohaydook1
30 Apr 2013 22:19
Thanks for the info. Saved me a lot of cussing. Guess I'll
Go the 4/1 route, but that bridge is waaay down the road.
1980 KZ750e
