4 into 1 pipe leaks
  • stroker220
  • stroker220's Avatar Topic Author
4 into 1 pipe leaks
26 Apr 2013 15:59
#584135
hi guys I have this pipe and it leaks around where the colar sleeve is on the pipe right beside where the spring is on all 4 all the way around... how can I seal this up to stop leaking...I have included a pic...thank you...
  • MFolks
  • MFolks's Avatar
Re: 4 into 1 pipe leaks
26 Apr 2013 16:15
#584137
What brand of pipe? Every Kawasaki I've owned(1977 Kz1000, and 1982 GPz 1100) had the exhaust system clamped to the exhaust ports by using the "Half Moon" holders and clamps. Tried a double exhaust gasket? I understand that the Suzuki gaskets for the exhaust are double in thickness, and www.z1enterprises.com can get them for you.
  • Dr. Gamma
  • Dr. Gamma's Avatar
26 Apr 2013 16:52 - 26 Apr 2013 17:06
#584142
Looks like a vintage Bassani Superbike pipe from the late 70's/early 80's. Someone must have added the springs and their mounts to your pipe. The stock Bassani pipe DO NOT come with the springs and their mounts. Remove the pipe and make sure all four ends of the header pipes are inline with a straight edge. I bet the one that is leaking is the one that does not line up with the other three!!! Carefully bend that pipe so it lines up with the other three. And make sure there is NO carbon build up on the inside or outside of the header pipes when they fit into the spigots. I used to tap each pipe with a big rubber mallet before and after I installed the springs.
I used to use a Kawasaki KX exhaust spring on my pipes, part number I think was 18071-003 if I remember right. I used Bassani pipes on all of my Kz's back then. And I sold many of them back in the day too. I NEVER had a exhaust leak from where you have yours. I used to use two springs per pipe on my bikes. My pipes never leaked, but did turn the Gunkote a real nice shade of light grey after a few hours of running but no leaks!! If you look at my posting of my Kz1000 under New Members "I want to ride again", you will see the discoloration of my pipe up near the head.
1986 RG500G 2 stroke terror.
Last edit: 26 Apr 2013 17:06 by Dr. Gamma. Reason: more info added.
  • donthaveakawman
  • donthaveakawman's Avatar
26 Apr 2013 17:23
#584145
I would cut those brackets off there and get longer studs then use the stock brackets or move those further down and use the stock brackets.
  • DoubleDub
  • DoubleDub's Avatar
26 Apr 2013 18:06
#584149
donthaveakawman wrote: I would cut those brackets off there and get longer studs then use the stock brackets or move those further down and use the stock brackets.
:blink:
  • zukdave
  • zukdave's Avatar
26 Apr 2013 20:13
#584168
New exhaust gasket's and then red high temp silicone on the spigot's
should seal it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • donthaveakawman
26 Apr 2013 23:16
#584194
don't forget the thread-lock anti-sieze on the studs/nuts
  • baldy110
  • baldy110's Avatar
26 Apr 2013 23:40
#584202
donthaveakawman wrote: don't forget the thread-lock anti-sieze on the studs/nuts
Are you serious? Thread lock on exhaust studs and nuts, yeah that will work. I will say it again proof read your responses.
  • donthaveakawman
27 Apr 2013 04:31
#584233
upon a closer glance, would you say that maybe it is not an exhaust leak but rather the oil from the valve cover dripping on the pipes? :laugh: :laugh: :laugh: :laugh: :woohoo: :woohoo: :woohoo: :laugh: :laugh: :laugh:
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
27 Apr 2013 09:00
#584240
I had a racing exhaust with similar fittings, the main flanges bolt to the head and the exhaust ends slip over the flange, the spring holds the exhaust to the flange. Unfortunately if the springs are too weak the exhaust gases actually push the exhaust away from the flanges. There will always be a slight leak where the exhaust slips over the flange but it'll leak a lot more if the springs are too weak.
  • zukdave
  • zukdave's Avatar
27 Apr 2013 19:56
#584297
donthaveakawman wrote: upon a closer glance, would you say that maybe it is not an exhaust leak but rather the oil from the valve cover dripping on the pipes? :laugh: :laugh: :laugh: :laugh: :woohoo: :woohoo: :woohoo: :laugh: :laugh: :laugh:
Upon closer glance your still a f'in dumb a$$.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: jonarmstrong
  • kenfowler123
  • kenfowler123's Avatar
01 May 2013 10:07
#585088
I HAD THE SAME PROBLEM WITH MY 82 KZ 1100 WHEN I TRIED TO INSTALL A mAC 4 INTO 1. i HAD A LEAK IN THE FIRST HEADER ON THE LEFT SIDE OF THE BIKE. aFTER TAKING THE SYSTEM ON AND OFF SEVERAL TIMES IT DAWNED ON ME THAT IT WAS NOT SEATING PROPERLY SO I DOUBLED UP ON THE COPPER GASKET AND THE PROBLEM WAS SOLVED.
1982 KAWASAKI KZ 1100 A SHAFT
