chain tensioner
  • jonarmstrong
  • Topic Author
25 Apr 2013 00:05 #583888 by jonarmstrong
chain tensioner was created by jonarmstrong
Was reading other posts and can't quite understand how the intake cam can be in a different position depending on whether you put the valve cover or tensioner on first. I can see that the tensioner may not put correct tension on the chain before it rolls thru a few times but with a spring setup that doesn't lock at any one position wouldn't it go to the point its gonna go to regardless? My bike runs great but I don't think I pulled the tensioner the last time I had the valve cover off and my OCD is really kicking my ass thinking about it :S
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
25 Apr 2013 00:29 - 25 Apr 2013 00:29 #583892 by steell
Replied by steell on topic chain tensioner
That applies to the 750 fours and the 650's with a HyVo style cam chain, don't know if it applies to the 998 motors or not.
I've never seen a four cylinder cam chain tensioner that didn't lock, might want to take another look at yours.
Last edit: 25 Apr 2013 00:29 by steell.
  • jonarmstrong
  • Topic Author
25 Apr 2013 00:50 #583897 by jonarmstrong
Replied by jonarmstrong on topic chain tensioner
So they do lock? Thought the two tapers just push against each other to push on the guide. But I guess if it pushed before the cover could do its thing it could be too tight??? Would removing the outside nut and taper and reinstalling correct this problem or does the whole tensioner have to come off?
  • Motor Head
25 Apr 2013 01:14 #583904 by Motor Head
Replied by Motor Head on topic chain tensioner
On your 82 KZ1000 engine, you need to have the wedge and spring out, so the cap off, when installing the valve cover. The tensioner plunger with just the main spring is ok.
The following user(s) said Thank You: jonarmstrong
  • jonarmstrong
  • Topic Author
25 Apr 2013 01:37 #583906 by jonarmstrong
So let me be totally clear. Remove cap, spring, and wedge and reinstall? Do I need to check anything else?
  • jonarmstrong
  • Topic Author
25 Apr 2013 01:37 #583907 by jonarmstrong
