- Thank you received: 1
KZ700 Idle Miss
- Marklorenzo
23 Apr 2013 10:16 #583677
by Marklorenzo
1984 KZ700 A1
KZ700 Idle Miss was created by Marklorenzo
Recently I had to put new coils on the 84 Kz700. Bike has always idled well after warm up but since coils its seems to stumble when sitting. Going down the road it runs like a champ. I have checked all connections and all seems good. Any suggestions? I had andrews yellow 3 ohm coils and went to dyna green 3 coils. Any ideas how I can figure this out.
1984 KZ700 A1
- baldy110
- Thank you received: 512
23 Apr 2013 13:18 #583689
by baldy110
Replied by baldy110 on topic KZ700 Idle Miss
Try adjusting your idle mixture screws. The new coils might either have a hotter spark or less spark so the plugs are reacting the new spark.
- loudhvx
- Thank you received: 1616
23 Apr 2013 13:21 #583690
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic KZ700 Idle Miss
Make sure it's not something silly like a flakey kickstand switch or neutral switch, if you bike has the engine-kill feature when the bike is in gear with kickstand up.
1981 KZ550 D1 gpz.
Other links.
- Marklorenzo
23 Apr 2013 13:46 #583698
by Marklorenzo
1984 KZ700 A1
Replied by Marklorenzo on topic KZ700 Idle Miss
Where are idle mixture screws located? I have one big nob inbetween all four carbs that adjusts the idle. Unfortunetly carbs are not my thing. Wish I knew more. But afraid to tear into them.
1984 KZ700 A1
- Motor Head
- Thank you received: 391
23 Apr 2013 13:52 #583699
by Motor Head
Replied by Motor Head on topic KZ700 Idle Miss
Check that you din't knock off the vacuum line to the Air Switching valve. Should be tee'd to the two outboard carbs, then up along under the tank to the valve. Or the vacuum line to the pet cock, #2 carb thats the inside on the left. Line goes up to the pet cock. #3 carb should have a vacuum cap.
- Marklorenzo
23 Apr 2013 13:55 #583701
by Marklorenzo
1984 KZ700 A1
My bike is set up where the two outboard carbs have lines coming off that just hang there. Not plugged into anything. The other two one goes to petcock and other is capped. Any ideas on that? I can update pics later
1984 KZ700 A1
- Marklorenzo
23 Apr 2013 14:05 #583702
by Marklorenzo
- baldy110
23 Apr 2013 17:27 #583734
by baldy110
What is with the valve attached to the green hose, is that your fuel line?
- Marklorenzo
23 Apr 2013 19:31 #583753
by Marklorenzo
1984 KZ700 A1
That is fuel line yes. Its a fuel shut off. I just did some digging. Checked timing. It's dead on. Checked all plugs. All very nice. I'm stumped. I have mac 4 into 1. And pods....bike came with pods so I figure it was jetted properly. But I will be putting a stock air box back on. I do have some popping from exhaust.
1984 KZ700 A1
- Marklorenzo
23 Apr 2013 19:31 #583754
by Marklorenzo
1984 KZ700 A1
1984 KZ700 A1
- gengomerpyle
- Thank you received: 17
23 Apr 2013 20:11 #583757
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic KZ700 Idle Miss
the big knob in the middle of the carbs is the idle adjustment.
1982 GPZ750R1 ELR
1971 Honda CB750K
- Marklorenzo
23 Apr 2013 20:26 #583761
by Marklorenzo
