Kz1000 engine issue help needed
22 Apr 2013 22:54 #583623 by floivanus
Kz1000 engine issue help needed was created by floivanus
Found a kz1000 for the motor, has three seperate obvious issues
Kickstart mechanism has been removed, i want it reinstalled what is involved here
The shift shaft end is buggered up and needs replaced, same question is this internal?
And one i already know what to do on; broken plug in head, it's drilling time!
Past; 78 kz1000, 83 kz550
Andrew
22 Apr 2013 23:10 #583626 by Kraz1
Replied by Kraz1 on topic Kz1000 engine issue help needed
floivanus wrote: Found a kz1000 for the motor, has three seperate obvious issues
Kickstarter Mechanism is Split the Case Halves.
Foot Shifter Shaft is external
Spark Plug is.... Better You than Me.. :lol: I'm teasin' ya, but it sucks.
22 Apr 2013 23:19 #583627 by floivanus
Replied by floivanus on topic Kz1000 engine issue help needed
Hey i cut my teeth as a car mechanic, good old 4.6 fords and broken plugs, no problem.
Well that sucks about splitting the cases to do the kicker, had figured that might be the answer, after driving 125 miles one way to get the bike though i wasnt leaving empty handed
Andrew
22 Apr 2013 23:27 #583629 by MFolks
Replied by MFolks on topic Kz1000 engine issue help needed
Ask Larry C about your problems with the engine: www.cavanaughracing.com/
23 Apr 2013 21:57 #583763 by floivanus
Is it a big deal to split the case to do the kickshaft? Or is it just flip the engine over pull pan and bottom half of case, motor is out of frame
What do you look for to find one of these shift shafts? Its a mkii motor
Andrew
