starter motor info
- dave the rave
starter motor info
22 Apr 2013 08:07
Hiya,i have a 1982 KZ1000 engine that i am using on a project,please can anyone tell me is there a starter motor that is compatible for this engine in the Kawasaki range,many thanks dave the rave
- Old Man Rock
Re: starter motor info
22 Apr 2013 08:31
Why use compatible when you can get one that is designed for your bike... Possibly need for something else in mind in your build...
Just in case...
Z1 has starters...
Z1 Starters...
Ricks motosports electrical...
Ricks KZ1000LTD Starters...
J/K/CSR model starters: Same part # 61-205....
Just in case...
Z1 has starters...
Z1 Starters...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- barney
22 Apr 2013 08:57
You can run a honda cb900F or 1100F starter with minor modifications. Index the wiring terminals,No biggy and they run a bit faster the the stock Kawy units
- dave the rave
22 Apr 2013 12:47
Hiya cheers for the info, i think i must have miss wrote my question, sorry,
what i ment to ask is would another kawasaki model starter motor fit a KZ1000
engine, i am unemployed due to injury so have small income for my project, and
find it easier to hunt for bits on ebay, if another model starter motor would
fit and work thats cheap then nice, yeah i would like to get the right one
but quite high cost, cheers Dave
23 Apr 2013 00:42dave the rave wrote: Hiya,i have a 1982 KZ1000 engine that i am using on a project,please can anyone tell me is there a starter motor that is compatible for this engine in the Kawasaki range,many thanks dave the rave
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
For example, kawasaki.com shows the same 1982 KZ1000 starter being used on 38 different Kawsaki models:
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)
KZ1000-K1 (LTD) (1981)
KZ1000-M1 (CSR) (1981)
KZ1000-M2 (CSR) (1982)
KZ1000-P1 (Police 1000) (1982)
KZ1000-P10 (Police 1000) (1991)
KZ1000-P11 (Police 1000) (1992)
KZ1000-P12 (Police 1000) (1993)
KZ1000-P13 (Police 1000) (1994)
KZ1000-P14 (Police 1000) (1995)
KZ1000-P15 (Police 1000) (1996)
KZ1000-P16 (Police 1000) (1997)
KZ1000-P17 (Police 1000) (1998)
KZ1000-P18 (Police 1000) (1999)
KZ1000-P19 (Police 1000) (2000)
KZ1000-P2 (Police 1000) (1983)
KZ1000-P20 (Police 1000) (2001)
KZ1000-P21 (Police 1000) (2002)
KZ1000-P22 (Police 1000) (2003)
KZ1000-P24 (Police 1000) (2005)
KZ1000-P3 (Police 1000) (1984)
KZ1000-P4 (Police 1000) (1985)
KZ1000-P5 (Police 1000) (1986)
KZ1000-P9 (Police 1000) (1990)
KZ1000-R1 (Eddie Lawson Replica) (1982)
KZ1000-R2 (Eddie Lawson Replica) (1983)
KZ1100-A1 (Shaft) (1981)
KZ1100-A2 (Shaft) (1982)
KZ1100-A3 (Shaft) (1983)
KZ1100-D1 (Spectre) (1982)
KZ1100-D2 (Spectre) (1983)
KZ1100-L1 (LTD Shaft) (1983)
ZN1100-B1 (LTD Shaft) (1984)
ZN1100-B2 (LTD Shaft) (1985)
ZX1100-A1 (GPz) (1983)
ZX1100-A2 (GPz) (1984)
- MFolks
23 Apr 2013 00:52
Using A Honda Starter In A Kawasaki
Buda from the www.kzrider.com forum wrote:
Will not turn the engine over....10.25 10 1 comp 1170 cc......took starter out and ran it with a battery....the starter spins strong but starts to squeal after a second.....also the shaft has a lot of play side to side. Bad starter I’m guessing What do you guys think?
Took the starter apart.....the bushing on the drive end is cracked
MFolks Wrote:
For a stronger starter motor, read this:
Using a Honda Mitsuba SM-220 Starter in the Kz (copied from the KZ rider website)
The CB F's used 2 different starters. Look for the one marked .8kw. They also have one that is .7kw. This owner noticed a difference when he installed his. He read that you can remove the outer housing, and rotate it. this will re-align the outer power terminal, to a better location. if you don’t do this, you will need to grind some metal from the chain cover to gain clearance. Also install a heavier gauge wire to the starter , I’d recommend 6 AWG(American Wire Gauge) welding cable with the correct terminal ends to match the treaded studs for the solenoid and starter motor. Don’t forget the cable from the battery to the solenoid.
The stock KZ starter is .6kw in size
www.stockers.com/index.php?dt=HS-29 (Mitsuba SM-220)
Buda Wrote:
Thanks MFolks, Just ordered the rebuild kit before I read your post....If that doesn't work out I'll give the Honda starter a shot.
Got a the Honda starter MFolks recommended (SM 220 12 volt 0.8 KW) on ebay...hell of a difference.....Turns over like the plugs are missing....I'm sure the new battery doesn't hurt, but its a hell of a difference.
- dave the rave
23 Apr 2013 04:42
A big thank you for all the info about starter motor for kz1000,
very helpful, thanks again, dave the rave
