crank case?
  • kenfowler123
  • Topic Author
20 Apr 2013 13:21 #583286 by kenfowler123
crank case? was created by kenfowler123
Hello everyone, first thing I want to say is thank you for all the great advise and suggestions I have been getting. I don't like going to a mechanic and prefer to do things myself. As for my recent dilemma, I replaced my stock air filter system with pod filters. I was wondering if I can seal off the crank case hole or do I need to get a filter? Dont want to create a problem by sealing it and if I do need a filter any suggestion on where and what type and size to get would be greatly appreciated. By the way, it is a 1982 KZ 1100 A shaft.
Thanks
1982 KAWASAKI KZ 1100 A SHAFT
20 Apr 2013 13:49 #583290 by daveo
Replied by daveo on topic crank case?
;) I like your bike!
Here is how I set mine up, before changing back to the air box recently.
The crankcase (breather) filter is a K&N unit 2" diameter, I believe. Had to open the hole up in the stock breather cover for the filter tube to friction-fit inside. The filter allowed the crankcase to breathe without blowing oil out of the filter element, even at 9000rpms.
1982 KZ1100-A2
  • kenfowler123
  • Topic Author
20 Apr 2013 13:56 #583291 by kenfowler123
Replied by kenfowler123 on topic crank case?
Thanks for the reply. Your big is @#$%$%^ing beautiful!!!!!
  • kenfowler123
  • Topic Author
20 Apr 2013 13:58 #583292 by kenfowler123
bike
20 Apr 2013 14:05 - 20 Apr 2013 14:07 #583293 by daveo
Ken, the edit feature has helped me on more than several occasions. :whistle:
Great rides!
Over and out...
1982 KZ1100-A2
Last edit: 20 Apr 2013 14:07 by daveo.
20 Apr 2013 15:01 #583303 by 650ed
Replied by 650ed on topic crank case?
Keep that airbox handy. ;)
20 Apr 2013 22:36 #583370 by daveo
650ed,
Keeping the air box is a great idea. :kiss:
The difference in performance is noticeable, quite enhanced with the pods/jetting.
It definitely breathes through more fuel/air with individual filters. The throttle response IS instantaneous and quick to red line, when set up that way.
:woohoo: But, I may go back for the thrill of it.
1982 KZ1100-A2
