opinions on glass bead blasting
- limitfish
20 Apr 2013 00:01
What do you guys think of glass bead blasting heads and cylinders. What should I cover? Can I do valves (stems covered)? Thanks, Tom
1977 KZ650 B1.
2000 Concours ZG1000
- Powerstroke_fan
Re: opinions on glass bead blasting
20 Apr 2013 08:33
You can glass bead the cylinder and head.just make sure you take it all apart and get all oil passages cleaned and cleared of ALL glass bead. You can also do valves with stems taped. I would try to plug all oil passages best as possible. I would also plug the cylinders in the jug. Thats what i did and it worked well for me.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- ThatGPzGuy
20 Apr 2013 14:16
make sure you put bolts in every threaded hole. it's tough to get the glass beads out of threads. And yes, as the previous poster said you have to clean and clean and clean. Those beads get everywhere even taped up.
Good luck,
Jim
Good luck,
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- LarryC
20 Apr 2013 17:42limitfish wrote: What do you guys think of glass bead blasting heads and cylinders. What should I cover? Can I do valves (stems covered)? Thanks, Tom
Get real glass bead...not that crushed glass crap they sell at most H.R. ot Tractor Supply stores. Use 30-40.
I do them all the time.
Larry C.
- APE Jay
20 Apr 2013 19:42
We then do extensive pressure washing. including direct blast to each threaded hole.
