Kawasaki Straight piping
  • kledda970
  • kledda970's Avatar Topic Author
18 Apr 2013 04:53
#582922
I have a 1979 kawasaki kz750, and i was wondering how i can do a custom straight pipe on it. the carbs are jetted w/ pod filters
Re: Kawasaki Straight piping
18 Apr 2013 09:13
#582934
If you really want to piss of the neighbors why not just put a police siren on it? :woohoo: At least that way you won't reduce the engine's performance. ;)
18 Apr 2013 09:31 - 18 Apr 2013 09:32
#582941
kledda970 wrote: I have a 1979 kawasaki kz750, and i was wondering how i can do a custom straight pipe on it. the carbs are jetted w/ pod filters
:unsure: Twin headers merging into single straight pipe exhaust, or twin headers with dual straight pipe exhausts?
Good Fortune! :)
Last edit: 18 Apr 2013 09:32 by Patton.
  • CrazyDuck
  • CrazyDuck's Avatar
18 Apr 2013 12:28
#582956
I have pretty much a straight pipe on my KZ900 after the Kerker 4-1. It is quiet until I lay into it. I can cruise around all day and not have any problems with too much noise but if I let her rip and shift at 10k, you can hear it clear as day from over 2 miles away.
I'd suggest some sort of proper muffling. What I am doing is taking some perforated tubing, making a couple end caps, wrapping the tube in the fiberglass muffler packing and sticking it in my straight pipe. Keeps the same look but allows you to get away with having more fun before the cops come to investigate. :woohoo:
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
  • kledda970
18 Apr 2013 14:57
#582965
twin headers with dual straight piping
  • jonarmstrong
  • jonarmstrong's Avatar
18 Apr 2013 16:42
#582970
So I have a 4 into 1 vance & hines drag pipe that i removed the baffle and took the finerglass off and reinstalled the baffle. Am I loosing performance? I really can't tell
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
18 Apr 2013 18:21
#582982
jonarmstrong wrote: So I have a 4 into 1 vance & hines drag pipe that i removed the baffle and took the finerglass off and reinstalled the baffle. Am I loosing performance? I really can't tell
That's hard to say, but the good news is that in your case the exhaust from all 4 cylinders still goes through 1 pipe. If, on a fairly stock engine for example, you were to cut all 4 pipes so they each ended individually rather than all hooking into a collector, the exhaust scavenging affect would be lost. The odds are extremely high that that would result in a loss of power. Ed
The following user(s) said Thank You: jonarmstrong, kledda970
  • bountyhunter
  • bountyhunter's Avatar
18 Apr 2013 20:23 - 18 Apr 2013 20:25
#582996
In general, screwing with the exhaust system at all on a bike loses power. The bike's are tuned pretty much on the peak by the manufacturer. Even the aftermarket pipes that give a "power gain" get it at the expense of low end torque loss and also they are tuned up to work with the bike's intake system (of course rejetting is required). Straight pipes are going to run like crap on a street bike. You might eventually get a power increase across the high end range but low and mid will suck. I have no idea what an "unpacked" baffle will run like?
Last edit: 18 Apr 2013 20:25 by bountyhunter.
  • jonarmstrong
18 Apr 2013 20:31
#582998
Here's what I got. Didn't have the money for a new pipe so I hacked up what I had n made this. Seems to have all the bottom end I need. Don't really ride wide open a lot and didn't ever have the factory exhaust so dont know what gains or losses I have achieved
Attachment IMAG0334.jpg not found
The following user(s) said Thank You: kledda970
  • turboking
  • turboking's Avatar
18 Apr 2013 21:33 - 18 Apr 2013 21:35
#583009
jonarmstrong wrote: Here's what I got. Didn't have the money for a new pipe so I hacked up what I had n made this. Seems to have all the bottom end I need. Don't really ride wide open a lot and didn't ever have the factory exhaust so dont know what gains or losses I have achieved
sorta looks like a turbo exhaust :pinch:
[IMG
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 18 Apr 2013 21:35 by turboking.
18 Apr 2013 22:34
#583016
Brit twin owners -- maybe even 650ed :lol: -- sometimes removed the mufflers and installed baffle inserts to reduce the noise.
Usually achieved degraded engine performance, and a not-very-manly exhaust sound.
Attachment Baffleinsertmuffler.jpg not found
Good Fortune! :)
  • jonarmstrong
18 Apr 2013 23:09 - 18 Apr 2013 23:11
#583023
Thanx for the input. Sorry for jumping in on a thread for my own gains but other peoples questions bring on my curiosity. Wish I had a kerker but its a run what u brung thing at my house! & patton, got a pretty manly sound goin on from my frankenstein exhaust
Last edit: 18 Apr 2013 23:11 by jonarmstrong.
