KZ750 E1 Piston rings
- stcyreeve
17 Apr 2013 20:37
I have a 1980 KZ750 E1 4 cyl. I recently honed the cylinders and need new Standard size rings. I have looked around and I have found several different stock numbers for supposedly std. rings. Could somebody please tell me what the real factory stock numbers are?
Thank you.
Thank you.
Re: KZ750 E1 Piston rings
18 Apr 2013 00:44
Some possibilities that might be worth further exploring:
www.gearhead.com/13008-5031.html#/s/KUS//13008-5031/1
www.partzilla.com/parts/detail/kawasaki/KP-13008-5031.html
www.japanesecycle.com/index.php?act=viewProd&productId=445
The following user(s) said Thank You: stcyreeve
- stcyreeve
18 Apr 2013 11:28
Thanks Patton, I will be ordering the parts.
I have one other quick question. What do you recommend for engine paint? I have read that some can cause overheating. I plan on painting the engine black. Any suggestions would be very helpful.
Thank you.
Thank you.
