no fire
- evilted
no fire
16 Apr 2013 20:15
was riding my 1978 kz1000 and it just up and quit and no it has no fire on it anyone have any ideas what the problem may be
- JR
Re: no fire
16 Apr 2013 20:52
Do you have lights, ignition etc ?
If its electrical then check main fuse, loose battery terminal.
- jeffasaki
Re: no fire
16 Apr 2013 20:55
you need to give us more info
check your fuses
check your fuses
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- MFolks
Re: no fire
16 Apr 2013 21:19
Ignition points, or does the bike now have electronic ignition, like the Dyna "S"? The Dyna's have a weakness in where the power supply attaches, as it's prone to corrosion and failure like this. The solution is to solder the joint,and cover it with heatshrink tubing, rather than use the supplied "Splice".
As suggested, check and replace the fuses. They are the AGX size,some auto parts stores carry them, and also at boating supply stores too.
- donthaveakawman
