kz 750csr twin
  • drummerjoe10
  • drummerjoe10's Avatar Topic Author
kz 750csr twin
15 Apr 2013 14:53
#582478
Hey guys, im new to the forum but have read nd used a lot of the info off here to work on my bikes but Ive run into something i cant find an answer to anywhere. I recently bought an 82 750csr twin, it had been sitting fr a few months so i cleaned to carbs n got it runnin pretty good and the other day it started popping on deceleration. After checking the plugs i noticed one that was white meaning it was running lean, not to my suprise because someones cut the header to straight pipes n I dont think they re-jetted it,so i pulled the carbs off and cleaned them out again and noticed where a previous owner had tried to get one of the pilot jets out (the one on the cylinder that was running lean, it was clogged up)and had all but stripped it n boogered it up pretty good, i couldnt get it out so i cleaned it the best i could and put the carbs back on, and now it has a knock towards the top end but i havent done anything except clean the carbs out. Its running wayy to strong and good to be anything major in my opinion but i was curious to get ya'lls thoughts on what it could be and how worried i need to be, thanks for any help in advance
Joe
  • bountyhunter
  • bountyhunter's Avatar
Re: kz 750csr twin
16 Apr 2013 03:45 - 16 Apr 2013 03:47
#582618
Popping on decel means lean pilot jets. Kawi runs them a little lean anyway, I would try going up two sizes.
You need a special screwdriver to fit the slot thickness and jet width/
Last edit: 16 Apr 2013 03:47 by bountyhunter.
  • drummerjoe10
Re: kz 750csr twin
16 Apr 2013 11:18
#582650
Ok cool thanks for the info, where's a good place to get the jets? Any idea what would make it knock after cleaning?
  • bountyhunter
Re: kz 750csr twin
16 Apr 2013 18:28
#582707
I wuld do a top-down clean on the fuel systems from tank, petcock, inline filters to carbs. Once you start cleaning things, rust powder or crud bits can flow down and block jets.
The following user(s) said Thank You: drummerjoe10
  • drummerjoe10
Re: kz 750csr twin
16 Apr 2013 22:45
#582742
thats what i did today between work, its still runnin good n that helped smooth it up a little but its still got the knock sound :huh: . I think I'm gonna take it to a shop here n see if they can get the stuck jet out, i tried a little today but didnt have any luck n i dont wanna screw it up any worse than it already is lol
