Anti-Seize information
  • MFolks
  • MFolks's Avatar Topic Author
14 Apr 2013 23:50
#582372
The following user(s) said Thank You: bluezbike
  • donthaveakawman
  • donthaveakawman's Avatar
Re: Anti-Seize information
15 Apr 2013 00:05
#582381
I didn't read it but it could ruin your spark plug ground qualities if you use too much so an occasional blast of carb cleaner never hurt anything.
  • loudhvx
  • loudhvx's Avatar
15 Apr 2013 00:27
#582387
I never leave home without it! (It's on every vehicle I own, in some place or other.)
15 Apr 2013 00:47 - 15 Apr 2013 20:04
#582392
donthaveakawman wrote: I didn't read it but it could ruin your spark plug ground qualities if you use too much so an occasional blast of carb cleaner never hurt anything.
It should not be used on spark plugs - see link for explanation. Ed
www.ngksparkplugs.com/pdf/TB-0630111antisieze.pdf
Last edit: 15 Apr 2013 20:04 by 650ed.
  • Kraz1
  • Kraz1's Avatar
15 Apr 2013 00:54 - 15 Apr 2013 00:58
#582397
Of course you didn't read before answering. What else is new. :laugh:
We use Copper for Steel Spark Plugs to Aluminum Heads with no failure, and common sense. (Read as Not Over Tightening)
CLICK
> Copper Anti-Seize
From the Permatex site:
A premium quality copper anti-seize and thread lubricant that may be used to prevent seizing, corrosion and galling where high temperature conditions exist. Contains a high percentage of micro-fine copper flakes in a semi-synthetic grease carrier and is fortified with high quality rust and corrosion inhibitors. Temperature range: -30°F to 1800°F (-34°C to 982°C).
Provides good electrical conductivity.
Last edit: 15 Apr 2013 00:58 by Kraz1.
  • donthaveakawman
15 Apr 2013 01:16
#582401
I don't know if I mentioned it but I went to tune up the taurus sho 6 cylinder for the first time in 30k miles and it is running great on all 4 cylinders. so as threadlock may not be necessary for ngk I did not know that thanks for the help. does the lining melt over time?
  • bluezbike
  • bluezbike's Avatar
15 Apr 2013 03:45
#582413
Is it advisable to use anti-seize when using SS bolts into aluminium (read: motor)...and when torquing head bolts now I am a bit curious about the efficiency of the torque wrench if (as in the article Ed posted) "As much as 90 percent of the torque applied to a fastener is used to overcome the friction of the interfacing surfaces" Seems that a lot of factors could affect the proper setting, for example if there is a tiny bit of oil on the threads....
79 KZ 1000 LTD
  • donthaveakawman
15 Apr 2013 03:55
#582414
yeah I put some on the jets inside the carburetor, who knows.
  • LarryC
  • LarryC's Avatar
15 Apr 2013 07:51 - 15 Apr 2013 07:55
#582422
Where do you guys come up with this stuff :laugh: I do believe the Torque-Tension Relationship to the Clamp Load has been disturbed by a Lack of Ground. Therefore Common Sense need not apply to anything coated with a lubricant when screwing..... :sick:
Larry C.
Last edit: 15 Apr 2013 07:55 by LarryC.
  • kzz1king
  • kzz1king's Avatar
15 Apr 2013 09:31
#582434
LarryC wrote: Where do you guys come up with this stuff :laugh: I do believe the Torque-Tension Relationship to the Clamp Load has been disturbed by a Lack of Ground. Therefore Common Sense need not apply to anything coated with a lubricant when screwing..... :sick:
You made a funny! :laugh:
Home built KZ1000 turbo setup
  • donthaveakawman
15 Apr 2013 17:30
#582511
the spark plugs are too large to be considered screws it is threading.
  • KZB2 650
  • KZB2 650's Avatar
16 Apr 2013 00:41
#582600
The Permatex 133K advanced formula says its made of alum, copper and grafite so it should be good for lube and conduct electricity just fine. I wouldn't feel right not using it after all these years.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
