- Thank you received: 10
Aluminum cam end caps
- Kitten Tooth
13 Apr 2013 00:22 #582062
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Aluminum cam end caps was created by Kitten Tooth
I got them aluminum cam end caps from Z1E for my 1981 KZ1000LTD. They are the ones that come with the length of O-ring. I was wondering.. do i have to use any type of sealant with these or do i just use the O-ring?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- justfreaky
13 Apr 2013 00:45 #582068
by justfreaky
1980 Kawasaki KZ1000 B4 LTD
1981 Suzuki XS1100 Special
1984 Honda VF500
Replied by justfreaky on topic Aluminum cam end caps
I've been looking at these also.
If I recall reading correctly, a light amount of sealant is recommended.
1984 Honda VF500
- Kitten Tooth
13 Apr 2013 01:37 #582079
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic Aluminum cam end caps
I know they work because my dad installed them on his bike (He too owns a 1981 KZ1000LTD) and the sealed up awesome. He says he recalls using some Permatex black on it hit he wasnt for sure.. so before i start slathering everything in sealant and torquing down bolts i figured id ask you guys
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- bountyhunter
- Thank you received: 337
13 Apr 2013 01:40 - 13 Apr 2013 01:41 #582080
by bountyhunter
Replied by bountyhunter on topic Aluminum cam end caps
My manual says the end plugs are supposed to be installed with some non-permanent sealer.
I thought the aluminum kind needed some fitting?
Last edit: 13 Apr 2013 01:41 by bountyhunter.
- justfreaky
13 Apr 2013 01:42 #582081
by justfreaky
1984 Honda VF500
New at this myself. My engine is an '80 KZ1000 LTD. I am using my engine for something other than a motorcycle. Will be interested to see opinions.
1984 Honda VF500
- Powerstroke_fan
- Thank you received: 83
13 Apr 2013 08:07 - 13 Apr 2013 08:10 #582110
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Aluminum cam end caps
Yes you will need to put some sealant on them. I used the red rtv. It worked great and no leaks. Mine didnt require any fitting. Just clean up the mating surfaces. I dont like the rubber ones. After a couple times they start to leak and get hard. I used to run aluminum ones on my kz head. Then when i steped up to the j model head, i had to get some. Unfortanly when i was looking for mine, the only place that carried them was american classix. But i havent had the first problem with them yet.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 13 Apr 2013 08:10 by Powerstroke_fan.
