Impact Driver from friend to foe
  • Killman
  • Killman's Avatar Topic Author
  • Now with 99% more ducks
07 Apr 2013 22:05
#581097
Tearing down my carbs, (at least that's the plan) for some general cleaning, polishing and checking. Also going to install a 3 stage kit. Figured it'd take a couple of hours. Started around noon Saturday.
Shows what I know. Everything was going along swell until thos Godd@%#$d freakin' oatmeal screws on one of my float bowls decided to do their level best impersonation of a fine French cheese. Then the ones on both holding plates decided that if the float bowls got to stay put, well then they'd be damned if they were going to move.
A day and a half later, after most of a can of Seafoam Deep Creep, numerous and exhuberant applications of the torch and some WWF-worthy beatdowns with my trusty impact driver, I'm down to 2 final screws on the back of that one stinking float bowl, (pant pant). Damn things are just behind enough of a ridge that I can't get a good grip on them with channel locks, pliers or magic goddamned missiles.
And now my old chum, my soulmate, my bosom buddy through thick and thin, My MotherF#$%ING impact driver has decided that it's not going to let me change bits for the final charge into the breach. :angry:
I am defeated. Screw the world and the screws it rode in on! It's officially beer o'clock.
1983 kz440 ltd
Quack
Re: Impact Driver from friend to foe
07 Apr 2013 22:10 - 07 Apr 2013 22:15
#581098
Remember - they are not Phillips screws; they are JIS screws (see link below). Also, Kroil is our friend. Soak stubborn fasteners with Kroil for 2 days and they come our without much drama. Ed
kzrider.com/forum/21-tools/532335-budget...ewdriver-tips#532335
Attachment 00000_2013-04-07.jpg not found
Last edit: 07 Apr 2013 22:15 by 650ed.
  • Killman
07 Apr 2013 22:20 - 07 Apr 2013 22:30
#581103
Thanks Ed. I'm pretty sure you're the one that told me about the JIS a couple of years ago. I'm using the right drivers. I also ordered some Kroil earlier this afternoon. Should get here in about a week or so. :laugh:
I'm more choked about not being able to get the bit out of my manual impact driver.
1983 kz440 ltd
Quack
Last edit: 07 Apr 2013 22:30 by Killman.
  • testarossa
  • testarossa's Avatar
09 Apr 2013 08:41
#581350
If all of the penetrating oil, JIS screwdriver bits, and impact drivers fail, take a dremel tool with a cutoff wheel and cut a nice straight slot in that screw head. Then you should be able to use a flat blade screwdriver to loosen that stuck screw. Be careful not to cut into your float bowl.
Replace those cruddy JIS screws with socket head capscrews for future conveinience.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Killman
14 Apr 2013 00:01
#582216
OK Ed, the Kroil got here and I've squirted some on the screws. Question, should I just put some into some sort of container and immerse the stuck areas entirely? Or reapply more Kroil at intervals?
Testarossa, if this stuff doesn't work, what's to stop those soft screwheads from just shredding away after I've slotted them with a dremel?
Thanks guys, I'm gonna go put some Kroil in my impact drivers bit-hole now :sick:
1983 kz440 ltd
Quack
14 Apr 2013 00:24
#582219
Killman wrote: OK Ed, the Kroil got here and I've squirted some on the screws. Question, should I just put some into some sort of container and immerse the stuck areas entirely? Or reapply more Kroil at intervals?
I just wet the area a with Kroil a few times a day (like in the morning, at dinnertime, and before bed). I have done that over a period of 2 or 3 days for fasteners that were really stuck and then when I gave them a try they loosened up. Ed
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
14 Apr 2013 09:41
#582253
I perfer to use my craftsman battery impact to remove stuborn screws. The impact takes them right out everytime. Just make sure you really push on the impact driver so it dont slip. also wouldnt reccomend using it to reinstall screws, removing only.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
14 Apr 2013 11:53 - 14 Apr 2013 12:48
#582259
I would be a bit leery about using a an impact on carburetors. I would be scared of cracking the carb body. Saver yourself some grief for the next time, and replace these screws with allen head stainless steel equivalents.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 14 Apr 2013 12:48 by KZJOE900.
  • Killman
14 Apr 2013 15:39
#582275
I've got the SS Allen Heads all ready to go. Just need to get these last two little b@$+@^ds out...
The heads are just too soft to take a bit. I don't want to have to drill them out. I think I'm gonna have to get a new impact driver, too. Blast and bother.
1983 kz440 ltd
Quack
  • Killman
17 Apr 2013 04:33
#582769
All right, the screws are out. Ended up using a chisel.
And the Pine Sol soak worked like MAGIC!!! So clean it's not even funny, they look almost new.
Just have to find the time to put them back together with the new innards; install the new fuel, vacuum and overflow lines with catch can; and then get the whole shebang running right.
Gonna be interesting with just one compression gauge, any advice would be welcome.
1983 kz440 ltd
Quack
  • geohaydook1
  • geohaydook1's Avatar
19 Apr 2013 14:16
#583111
:ohmy: After all these years... JIS? Who knew?
1980 KZ750e
1981 KZ650 csr (fate undecided)
