- Thank you received: 5
Square headlight HID conversion woes
- staniel
07 Apr 2013 21:40 - 07 Apr 2013 21:43 #581082
by staniel
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
Square headlight HID conversion woes was created by staniel
Has anyone successfully installed a Bikemaster HID conversion on one of these rectangular reflectors on some of our KZs?
The original H4 bulb has a flat spot for the spring to push down, and the ring slots into the .."frame".
The replacement, the HID bulb, seems to offer no way of keeping the bulb in - the spring can't sit on a flat spot and the metal lock ring is too small to fit over the plastic part of the bulb.
I'd love to hear about what other folks have done to make this happen!
Attachment IMG_20130407_171841.jpg not found
Last edit: 07 Apr 2013 21:43 by staniel.
- 4TheKZ1000
- Visitor
07 Apr 2013 23:07 - 07 Apr 2013 23:10 #581113
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Square headlight HID conversion woes
is there another black cover that goes with it....goes over plug and down to bulb, 2 to 3 inches in dia.
Last edit: 07 Apr 2013 23:10 by 4TheKZ1000.
- MFolks
- Thank you received: 540
07 Apr 2013 23:19 #581118
by MFolks
Replied by MFolks on topic Square headlight HID conversion woes
On the stock headlight bulb, there's a rubber dust cover, is your's missing?
- staniel
07 Apr 2013 23:23 #581121
by staniel
Replied by staniel on topic Square headlight HID conversion woes
Nope, there's no black rubber dust cover. The photo you attached looks like a round light. Mine is the rectangular one that came with the L3. My other L3's headlight also didn't have one, IIRC.
Here's the HID bulb thing.
Attachment IMG_20130407_191747.jpg not found
- staniel
11 Apr 2013 11:21 #581794
by staniel
So, I figured it out: it takes some disassembly of the bulb thing. You have to unscrew the black plastic thing from the metal thing where it says "lock/open". When you take it out you can use the spring to hold down the metal and plastic receptacle. Once the spring and lockring are in place, you can screw the bulb back in.
Now I just have to figure out how to get the wiring taken care of and then be disappointed by the results!
- kzz1king
- Thank you received: 52
11 Apr 2013 12:25 #581804
by kzz1king
Home built KZ1000 turbo setup
Replied by kzz1king on topic Square headlight HID conversion woes
A lot will be determined by the reflector and how well it cuts off the beam vertically. I put one on my Concours and it turns night into day. I was not afraid to ride after dark anymore until I discovered how thick the bugs are then! Good fortune.
Wayne
Wayne
