Yes, that should work fine. I like to use lots of WD40 when I deglaze, clean the bores with Hot Soapy water when you are done, then rub in 1 drop of oil per bore to keep rust away.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
The following user(s) said Thank You: nivlac
