cam cap bolts?
  • brianrae33
  • brianrae33's Avatar Topic Author
cam cap bolts?
06 Apr 2013 13:26
#580870
are the cam cap bolts made of a particular steel? Or can i find them at a hardware store??
1982 kz1000ltd
  • wireman
  • wireman's Avatar
Re: cam cap bolts?
06 Apr 2013 13:44
#580872
The ones I use are grade 10.9 6mm x 50mm.
Theyre a little longer than stock so I put a hardened washer under each bolt and still have extra threads so it will be further down into the hole before it has to start pulling against camshaft.
