Oil Light flickers at idle and on at 4500 rpm
  • bluezbike
  • bluezbike's Avatar Topic Author
05 Apr 2013 23:22
#580782
Hi all,
As the title says on my 650 B....goes away with slight acceleration at idle but then comes on again at 4500 disappears above or below 4500....no gas in oil. Any ideas?
Many thanks
79 KZ 1000 LTD
  • LarryC
  • LarryC's Avatar
Re: Oil Light flickers at idle and on at 4500 rpm
06 Apr 2013 09:27
#580826
It's probably the sending unit. NOTE that is a plain bearing engine so investigate and resolve the situation ASAP. Could be as simple as the sending unit....could be an oil pump screen all clogged up.
Larry C.
  • bluezbike
07 Apr 2013 00:16
#580978
Will do Larry, thanks
79 KZ 1000 LTD
  • jonarmstrong
  • jonarmstrong's Avatar
08 Apr 2013 23:39
#581308
My 1000 did the same thing. Ended up being sludge and trash in the pan. Had the pickup screen totally clogged.
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
