clutch issue help, im stumped.
  • dsmking
  • dsmking's Avatar Topic Author
05 Apr 2013 07:54
#580662
Bike:1980 kz1k ltd.
Last season I had an issue with the clutch not engageing when I pulled in the lever, I just recently started working on the bike again and
It's time to figure out what's up, so I was messing with it yesterday adjusting the nut and screw that puts pressure on the clutch rod and nothing would work, when I put the bike back together I started it up and (I know this is not good) pulled in the clutch lever and slaped it into gear , bike lurches forward and dies , did this a few times and after about the forth try it all of a sudden worked, I could pull in the lever put it in gear and the bike would not move ??? I had a few things to do to it and took the chain off for a good cleaning, had to take side cover off for the front sprocket, and after I was done I put it back to gether and now I have the same problem??? A little insight on whats up would be amazing, thanks guys.
live fast die young.
  • Polar_Bus
  • Polar_Bus's Avatar
Re: clutch issue help, im stumped.
05 Apr 2013 09:00
#580671
dsmking wrote: Bike:1980 kz1k ltd.
Sometimes what can happen is the constant long term force from the clutch not being used can actually "squeeze" the oil out from between the clutch friction plates causing them to stick to the driven plates. The only solution is to disassemble the clutch, coat the plates with fresh oil and you will be all set. It's always a good idea to start your bikes up and run them ocassionally to keep everything inside the engine and trans "wet"
Bikes:
'84 GPz1100
'06 HD Fatboy
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
05 Apr 2013 10:43
#580683
What Polar Bus said is correct. Your clutch plates are just sticking together. Mine do that after the bike sits a while. Sounds like yours is pretty bad, so you need to remove and lightly sand the steel clutch plates. 400 grit is fine, but really clean them off before you reinstall. When you reassemble the plates, have them wet with trans oil.
After that, just follow the clutch adjustment procedure in the service manual. Make sure you clean and lube the cable and have plenty of slack before adjusting the clutch release mechanism.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • dsmking
05 Apr 2013 13:55
#580712
Thanks fellas ill dig into that and see what I get.
05 Apr 2013 14:09
#580714
Also, try this - with the engine turned off and the bike in first gear, pull the clutch lever in and hold it in while you rock the bike back and forth on the ground. If the clutch plates are stuck together doing this will often break them free. My old BSA had a racing clutch with aluminum plates, and I had to perform this ritual every morning. Ed
  • dsmking
05 Apr 2013 17:07
#580737
Haha I did that for a half hour lol this mourning I got it to break free again , I think it just needs to be ridden :/ carbs are geting refreshed this weekend, hope fully i will get it back running good, this bike hasn't gone for a real ride since be for I was born lol
