kz650 starting issues
- lazy5892
04 Apr 2013 21:57
Just as I think everything is just about good to go, something else comes up. Whenever I hit the starter button, the engine cranks over a few times then makes an awful grinding sound and the engine no longer cranks. I am unsure if its the starter clutch or the starter clutch gears. If anyone has some input before I go ahead and buy the rebuild kit that would be awesome! I just do not want to buy something I do not need.
- baldy110
Re: kz650 starting issues
04 Apr 2013 22:13 - 04 Apr 2013 22:15
Yep it's your starter clutch. Along with the starter clutch rebuild kit you will need the clutch cover gasket, pan gasket and exhaust pipe header gaskets.
Last edit: 04 Apr 2013 22:15 by baldy110.
The following user(s) said Thank You: lazy5892
- lazy5892
04 Apr 2013 22:48
I was afraid you'd say that, well at least it should be a fun little project. Thanks for your help, i do appreciate it!
