how to oil your clutch cable in ten easy steps
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
02 Apr 2013 05:12
#580129
yes that's right folks the cable that you should depress with your left hand everytime you shift gears. it needs to be oiled and it runs down under the engine of your kawasaki motorcycle.
the process includes several steps, they are as follows;
1 find the bolt and nut that your clutch lever pivots on.
2 undo that bolt and set it aside as you will need it for reassembly.
3 line up the adjuster so you can slip the cable through them.
4 take the cable out of the lever and slip it through the adjusters.
5 find a sandwich baggy and a rubber band.
6 find some oil.
7 fill the bag with oil and wrap the rubber band around the bag sealing it to the outer clutch cable.
8 drain the oil into the cable.
9 reverse the steps I have just provided.
10 work the cable back and forth and be very careful of extra oil that may leave a mess or cause your tire to slip.
Attachment ccoiling1.jpg not found
Attachment ccoiling2.jpg not found
  • bountyhunter
  • bountyhunter's Avatar
Re: how to oil your clutch cable in ten easy steps
02 Apr 2013 15:58
#580210
I hang mine up from the rafter in the garage and spray in the multi purpose teflon spray lube into the top and let it run out the bottom. Works great takes 30 seconds.
  • martin_csr
  • martin_csr's Avatar
02 Apr 2013 18:17 - 02 Apr 2013 18:20
#580251
My way is pretty much like bountyhunter's, except I use a homemade cable luber.... see yellow funnel & tubing in pic... just shove it onto the end & spray. The funnel collects the overspray & redirects it back to where you want it.
Last edit: 02 Apr 2013 18:20 by martin_csr.
  • gengomerpyle
  • gengomerpyle's Avatar
02 Apr 2013 18:57
#580256
i just get a sandwich bag and cut a corner off, then insert cable in hole. i tape the hole up to the cable and then spray until i see the oil going out of other end.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • DesertKZ
  • DesertKZ's Avatar
02 Apr 2013 19:10 - 02 Apr 2013 19:11
#580259
Attachment CableLifeTool.jpg not found
I use one of these tools not only on my bikes but boat as well. Can lube a cable in about 20 seconds when attached to an aerosol can of Cable Life.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Last edit: 02 Apr 2013 19:11 by DesertKZ.
  • donthaveakawman
02 Apr 2013 19:25
#580260
martin_csr wrote: My way is pretty much like bountyhunter's, except I use a homemade cable luber.... see yellow funnel & tubing in pic... just shove it onto the end & spray. The funnel collects the overspray & redirects it back to where you want it.
I like the fuel tank, what I did was kinda messy and I used 10w40 and way too much. the throttle cable had a plastic liner that I wasn't sure of but it seems to have worked, now I need to degrease the garage floor.
  • loudhvx
  • loudhvx's Avatar
02 Apr 2013 21:35
#580284
gengomerpyle wrote: i just get a sandwich bag and cut a corner off, then insert cable in hole. i tape the hole up to the cable and then spray until i see the oil going out of other end.
My exact method. Don't even need to remove the cable, just disconnect the lever end.
  • bluej58
  • bluej58's Avatar
02 Apr 2013 21:53
#580292
I'm with you Lou ;)
78 KZ1000 A2A
  • donthaveakawman
02 Apr 2013 21:58 - 02 Apr 2013 22:02
#580293
you could attach the sandwich bag to a funnel also.
Attachment boyblue.jpg not found
Last edit: 02 Apr 2013 22:02 by donthaveakawman. Reason: picture
  • riturbo
  • riturbo's Avatar
04 Apr 2013 11:14
#580532
I have one of those too. Work great.
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
