spark plugs
  • jonarmstrong
  • jonarmstrong's Avatar Topic Author
spark plugs
01 Apr 2013 23:28
#580081
I'm new to this forum but have bn reading for a while now I'm building an 82 Kz1000k and definately appreciate the knowledge I've gained from u guys. Finally got my bike on the road to be able to see what else I need to do. (A lot!!). Was reading the other day on a post concerning plugs and resistor caps and I'm a little confused. I'm running bpr8es plugs w stock coils and wires. Is this ok or should I be running something else? I did notice the spark was kindof weak
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
  • Motor Head
  • Motor Head's Avatar
Re: spark plugs
01 Apr 2013 23:46
#580086
2 things with those plugs. First the "R" in the part # is a resistor type, you don't want that. Then second the "P" is a projected electrode, again not correct. Get some B8ES or equivalent. Check my signature for a pdf version or the factory manual. I have the 82 K2 also.
Welcome to the KZR forum. Look in "File Base" upper right hand corner in the KZR tool bar for lots more info.
The following user(s) said Thank You: jonarmstrong
  • MFolks
  • MFolks's Avatar
Re: spark plugs
01 Apr 2013 23:46
#580087
I'd get regular plugs without the resistor, as the sparkplug caps probably have a 5000 ohm resistor in them.
Ignition Coils And Sparkplug Wire Choices
What came with the bike, were ignition coils that even when new were marginal, add years of cooking under the tank in the stop and go traffic, and the coils will probably fail when hot.
Replacement coils can be bought at www.z1enterprises.com I believe “Emgo” is the brand. They also carry the popular Dyna 2.2 and 3 ohm coils, along with replacement sparkplug wires.
Now, you have a choice on sparkplug wires:
1.Copper plug wires with no supression caps (the best choice, but will produce audio noise on Radio’s and TV’s). Not only do the copper core wires deliver better spark, they will also deliver a much longer lifespan - carbon core wires are prone to erratic spark delivery and early breakdown, & short lifespan.
2.Copper plug wires with supression caps (a built in 5000 ohm resistor, that can sometimes fail, like what came with the bike). These should be checked with a multimeter now and then, as heat can cause them to become intermittent.
3.Copper plug wires with no supression caps, but using resistor plugs(the “R” in the plug number).
4.Supression plug wires with no supression caps.
NEVER use resistor plugs combined with supression caps along with supression plug wires, as now there will be possibly three (3) sources of resistance in the secondary windings of the ignition coils, greatly reducing the spark energy.
Another choice is the Accel 3 ohm coils, with a similar, primary(small wire)electrical connection, using ring terminals as the Dyna ignition coils do. Whatever brand of coil you go with, make sure the primary wires will clear the mounting hardware, as the spacers come close, possibly blowing a fuse. Some riders have replaced the metal spacers with non conductive Nylon spacers, reducing the chance of an electrical problem.
7mm sparkplug wires will fit the stock ignition coils(if they have replaceable wires, indicated by screw off caps on the coils with ridges). The sparkplug wires fit into a port with a brass ”Stinger” that goes into the sparkplug wire or lead(the Brit’s. Canadians, and other countries call the sparkplug wires (“High Tension Leads”).
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: spark plugs
01 Apr 2013 23:52 - 01 Apr 2013 23:54
#580089
Jon,
It is my understanding that in order to avoid causing radio static either your spark plugs OR your caps should have a resistor in it... but not both. Your plug id is for a resistor plug. If you combine that resistance with a resistor cap, your spark would be very weak. Paul
Last edit: 01 Apr 2013 23:54 by slayer61. Reason: spelling issues
  • jonarmstrong
Re: spark plugs
02 Apr 2013 01:00 - 02 Apr 2013 01:18
#580112
Attachment IMAG0323.jpg not found
Thanks for the info. It's great being able to talk to people who know what they are talking about. I've always said I can make them run, its the making them run right that I have a problem with! I'll invest in the new plugs tomorrow probably have to wait till payday to upgrade the coils n wires this is my first Kz and I'm really enjoying it but I have to know... Are all these bikes so noisy? I don't have any knocking or ticking, just a lot of rotation noise. Is there any way to adjust the timing chain tension? It has the auto tensioner and i cleaned and lubed it well before installation
Last edit: 02 Apr 2013 01:18 by jonarmstrong. Reason: add pic
  • MFolks
  • MFolks's Avatar
Re: spark plugs
02 Apr 2013 15:23
#580198
Here's a manual cam chain tensioner:
www.kriegercamchaintensioners.com/ Othere's are available from www.aperaceparts.com and www.redlinecycle.com
  • jonarmstrong
Re: spark plugs
02 Apr 2013 16:42
#580220
One more question...b7es or b8es?
  • MFolks
  • MFolks's Avatar
Re: spark plugs
02 Apr 2013 16:45
#580222
B8ES is what Kawasaki recommended, if you want a Denso sparkplug, get the W24-ESU gapped the same as the NGK is.
  • jonarmstrong
Re: spark plugs
02 Apr 2013 22:17
#580294
The bike loves the new plugs and a full tank of non-ethanol gas! Thanks for the help guys.
