Season prep work
  • Kevin STP
  • Kevin STP's Avatar Topic Author
Season prep work
01 Apr 2013 19:34
#580006
Took a ride this weekend,winters over and I am recovering nicely from shoulder surgery.Now to the repairs-
1-Oil leaks from top end,gasket time and Orings at oil ports.I noticed when adding oil that the crankcase had pressure is this normal.Could this be the cause of increased oil burning? I rode all last summer and began to notice oil burning at the end of the season,the bike still ran strong,has about 18k miles. 83 Spectre 750.
83 Spectre 750
Re: Season prep work
01 Apr 2013 21:55
#580039
Would sniff test and check the crankcase oil for possible fuel contamination.
  • steell
  • steell's Avatar
01 Apr 2013 22:12
#580046
Crankcase vent might be plugged.
  • baldy110
  • baldy110's Avatar
01 Apr 2013 22:22
#580053
Also a sign of worn rings. Worn out rings allow cylinder presure by them and then pressurizes the crankcase. A leak down check can confirm that.
