low compression w/ fixed preventative maintenance.
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
31 Mar 2013 00:37
#579736
so from what I understand connecting exhaust reed valves with a hose will close them off.
My engine, who knows if it is original-kz750ee011229, has the emissions hoses on carbs 2 and 4, which coincidentally those cylinders lost a lot of compression right before my valve adjustment.
[img]http://http://cdn.memegenerator.net/instances/400x/35162939.jpg[/img]
I have noticed closing the throttle will cause it to pop and that would be when the vacuum hoses would get the most pull.
  • DoubleDub
  • DoubleDub's Avatar
Re: low compression w/ fixed preventative maintenance.
31 Mar 2013 01:25 - 31 Mar 2013 03:33
#579742
Last edit: 31 Mar 2013 03:33 by DoubleDub.
  • DoubleDub
31 Mar 2013 03:24 - 31 Mar 2013 03:33
#579753
  • donthaveakawman
31 Mar 2013 03:26
#579754
then what does emissions hoses have to do with carburetors wise guy.
  • DoubleDub
Re: .
31 Mar 2013 03:36 - 31 Mar 2013 15:39
#579757
Last edit: 31 Mar 2013 15:39 by DoubleDub.
