Stutter when I'm above half throttle
  • Matteson
  • Matteson's Avatar Topic Author
30 Mar 2013 20:19
#579674
Started doing this after a long ride today. Carbs are freshly rebuilt. Valves are within clearance. Plenty of fuel. Both the lines are feeding the carbs well. It did this a while back and the screw that holds the condensers was loose so with high revs it was shorting out. I just checked the screw again on the points plate and it was fine. All the screws that hold the points are tight. Timing maybe? I just had a dwell meter then the inductive light in her. Maybe check that again? It rode very strong yesterday. Then on the way home I went to pass a car and it stuttered so I let off and put the tank on reserve and it didn't help. Any ideas?
KZ 900-a4
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Stutter when I'm above half throttle
30 Mar 2013 20:34
#579680
old battery will do this...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • baldy110
  • baldy110's Avatar
30 Mar 2013 21:12
#579683
Not having a full 12 volts to the coils will also act like that.
  • CrazyDuck
  • CrazyDuck's Avatar
30 Mar 2013 21:31
#579689
Try turning the headlight off when it starts to stumble. If it improves, it's time for a battery.
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
  • Matteson
30 Mar 2013 21:38
#579693
baldy110 wrote: Not having a full 12 volts to the coils will also act like that.
I just did the coil mod so I have the same voltage at the coils as the battery. I'll check it guys.
KZ 900-a4
  • peter1958
  • peter1958's Avatar
  • Banned
  • Banned
30 Mar 2013 22:05
#579702
Could be a few things. lube the timing advancor. springs old in advancor. starved for fuel. vent in gas cap could be clogged
  • Matteson
31 Mar 2013 13:48
#579802
checked the gaps on the points again one was off. but a nut was striped out so I couldn't correct that. now i'm down until I get that fixed.
KZ 900-a4
  • Matteson
01 Apr 2013 07:41
#579904
Has anybody had problems with the relay(coil mod) vibrating and causing the bike to cut out? Just a thought.
KZ 900-a4
