Head swap 650C-1
- gsnfl
Head swap 650C-1
30 Mar 2013 09:17
I tried doing my homework on this one but I'm in over my head(s) so to speak. I have a 77 650C-1 with much valve and head problems. I found a head for a 79 650B3. Would this swap work? I did find that the 79 had the auto cam tensioner and mine doesn't. I'm talking swapping the whole shebang...head, valves everything above the piston tops.
Grassy-Ass!
Grassy-Ass!
77 KZ650 C1 basket case project-blowed up and parted out
83 KZ550 M1-Prince to Toecutter transition
Re: Head swap 650C-1
30 Mar 2013 10:06
That should work fine. Kawasaki.com gives the same part number for the C1 and B3 head. Ed
The following user(s) said Thank You: gsnfl
- gsnfl
30 Mar 2013 17:47
I am now breathing easier...Thank You!
- baldy110
30 Mar 2013 21:25
Yes it will work, done it numerous times. Generally if the engiens use the same style cam chains then the heads are interchangable.
