Hard to start and weak when running
- sakiguy
28 Jun 2006 19:06
Well, I was off to work....and usually my bike starts right up. But it's been giving me trouble lately. Doesn't seem to want to start right up like it normally does. You will hear the starter sound whine but the engine has trouble engaging. Once the engine does engage and I start to ride the bike doesn't seem to have much power. It's not the battery which read 12.4 volts. Checked my connections and made sure they were tight. I'm thinking I should probably change the plugs, as I had the same spark plug wires for 2 years now. Not too sure though, what do you guys think?
1983 KZ750 N2 Shaft
- wireman
Re: Hard to start and weak when running
28 Jun 2006 20:49
thank god,i thought you guys were looking in my bedroom window again !
Post edited by: wireman, at: 2006/06/28 23:50
- wiredgeorge
29 Jun 2006 06:30
Are your valve clearances adjusted? Have you checked compression? Are all cylinders firing? Test by spraying with water when the bike is hot. Water vaporizes on cylinders that fire and will roll off where they are not. There isn't enough info in your post to get started diagnosing whatever the problem may be. Describe your state of tune...
- sakiguy
03 Jul 2006 01:18
Sorry I didn't describe the problem well enough. Basically the bike had a hard time starting...but when it started it struggled to stay running...and when running it was very sluggish...as if it lacked power. I searched through the forums and decided that it was probably bad gas.
I pumped the gas out of the tank. I let the bike run with the gas lever to off until it stopped running. Then I put the new gas in the tank and switched the gas to ON. I ran it and it's running like it use to. I believe the old gas was from a Shell station. I used Mobil this time round. It's running great now
1983 KZ750 N2 Shaft
