Hunting For KZ750-B1 Cylinder Head Bolts
26 Mar 2013 00:49 #578802 by mind2find
Hunting For KZ750-B1 Cylinder Head Bolts was created by mind2find
We're putting the cylinder head back on after replacing the gasket and one of the bolts snaps. They are the ones that go up from the bottom into the cylinder head.
We can't find them anywhere except for a couple sketchy hand-written eBay bags. Does anyone know where we can buy some of these? Don't want to try any others because this one snapped even with a torque wrench. :pinch:
Part #: 92003-159 / BOLT, HEX HEAD, 6X34
We've been told not to use ones from the hardware store because they're not designed for engine applications and high heat.
Any help would be much appreciated, thanks!!!
-M
1976 KZ-750B1 (late model)
1976 KZ-750B1 (early model) Parts Bike
Boston, MA
  • wireman
26 Mar 2013 01:04 #578805 by wireman
Replied by wireman on topic Hunting For KZ750-B1 Cylinder Head Bolts
Are you talking about the cylinder studs? :)
26 Mar 2013 01:17 #578807 by mind2find
Replied by mind2find on topic Hunting For KZ750-B1 Cylinder Head Bolts
wireman, fortunately i am not! :)
these are the small bolts that face up (in other words, upside down) and pull the cylinder head down onto the cylinder. They are in the front (just 1 if memory serves) and 2 on the back of the cylinder, under the carbs.
it's been a while since i've worked on this bike, so i don't remember where to find the fiche.
Boston, MA
  • wireman
26 Mar 2013 01:30 - 26 Mar 2013 01:33 #578810 by wireman
Try boltdepot.com,them got those bolts in grade 10.8(metric version of grade 8 I think,or close to it)
for $.18 each :)
Don't forget those little bolts are tightened in inch lbs,not foot lbs.
Normally Id just put a little blue lock tite on them and snug them up with a 1/4 drive so you don't over tighten them :)
Last edit: 26 Mar 2013 01:33 by wireman.
26 Mar 2013 01:44 #578811 by mind2find
wireman, thanks for the lead. i didn't know about them. hopefully they're quality is better than any cheap stuff found in a hardware shop.
snugging up sounds fine on a regular fastener bolt, but since we took the top end off to prevent any more oil from leaking out around the main gasket, i'm gonna want to tighten it down to spec.
Boston, MA
26 Mar 2013 04:33 #578824 by bountyhunter
Replied by bountyhunter on topic Hunting For KZ750-B1 Cylinder Head Bolts
They are 10 mm bolts that torque to about 110 inch-pounds max.
  • donthaveakawman
  • Visitor
26 Mar 2013 04:42 #578826 by donthaveakawman
Replied by donthaveakawman on topic Hunting For KZ750-B1 Cylinder Head Bolts
I think APE would have them.
  • wireman
26 Mar 2013 08:35 #578837 by wireman
donthaveakawman wrote: I think APE would have them.
Attachment caution_2013-03-26.jpg not found
:laugh:
26 Mar 2013 10:06 #578851 by Patton
Replied by Patton on topic Hunting For KZ750-B1 Cylinder Head Bolts
Could give APE a call --
www.kzzone.com/
Good Fortune! :)
26 Mar 2013 10:09 #578852 by 650ed
Replied by 650ed on topic Hunting For KZ750-B1 Cylinder Head Bolts
If you want to play it safe you could just get Genuine Kawasaki parts. If you're lookiing for the bolts marked #3 in the diagram below this vintage parts house has them. Ed
www.nwvintagecycleparts.com/search-resul...rch.x=10&search.y=13
Attachment 00000_2013-03-26.jpg not found
  • wireman
26 Mar 2013 10:23 #578856 by wireman
Theres nothing special about the Kawasaki version of the bolt,other than the price of course! :woohoo:
26 Mar 2013 10:30 #578859 by 650ed
wireman wrote: Theres nothing special about the Kawasaki version of the bolt,other than the price of course! :woohoo:
Understood, but at least they will work as well as the originals. The problem with hardware store bolts is that you don't know which province in China they came from or the blend of pot metal they contain. :laugh: :laugh: :laugh:
