Hunting For KZ750-B1 Cylinder Head Bolts
- mind2find
We can't find them anywhere except for a couple sketchy hand-written eBay bags. Does anyone know where we can buy some of these? Don't want to try any others because this one snapped even with a torque wrench. :pinch:
Part #: 92003-159 / BOLT, HEX HEAD, 6X34
We've been told not to use ones from the hardware store because they're not designed for engine applications and high heat.
Any help would be much appreciated, thanks!!!
-M
1976 KZ-750B1 (late model)
1976 KZ-750B1 (early model) Parts Bike
Boston, MA
- wireman
- Thank you received: 299
- mind2find
these are the small bolts that face up (in other words, upside down) and pull the cylinder head down onto the cylinder. They are in the front (just 1 if memory serves) and 2 on the back of the cylinder, under the carbs.
it's been a while since i've worked on this bike, so i don't remember where to find the fiche.
Boston, MA
- wireman
for $.18 each
Don't forget those little bolts are tightened in inch lbs,not foot lbs.
Normally Id just put a little blue lock tite on them and snug them up with a 1/4 drive so you don't over tighten them
- mind2find
snugging up sounds fine on a regular fastener bolt, but since we took the top end off to prevent any more oil from leaking out around the main gasket, i'm gonna want to tighten it down to spec.
Boston, MA
- bountyhunter
- Thank you received: 337
- donthaveakawman
- Visitor
- wireman
donthaveakawman wrote: I think APE would have them.
Attachment caution_2013-03-26.jpg not found
:laugh:
- Thank you received: 2098
- Thank you received: 2829
www.nwvintagecycleparts.com/search-resul...rch.x=10&search.y=13
Attachment 00000_2013-03-26.jpg not found
- wireman
wireman wrote: Theres nothing special about the Kawasaki version of the bolt,other than the price of course! :woohoo:
Understood, but at least they will work as well as the originals. The problem with hardware store bolts is that you don't know which province in China they came from or the blend of pot metal they contain. :laugh: :laugh: :laugh:
