- Thank you received: 5
KZ750L leaking oil cooler lines at pan
- staniel
24 Mar 2013 18:59 - 24 Mar 2013 19:00 #578598
by staniel
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
KZ750L leaking oil cooler lines at pan was created by staniel
I did a preliminary search and didn't find much. I wonder if anyone else has had trouble with the oil coolers leaking at the connection to the oil pan. I found mine had dumped a fair amount onto my exhaust yesterday, so I pulled the exhaust, drained the oil, tried to clean the surfaces, put some black permatex on them and snugged 'em back up.
It's still leaking today. I wipe it clean, then ride it and see a droplet at the bottom, waiting to fall, and my exhaust stays freshly oiled, too. It's certainly not dumping, but it's not making me feel good.
Has anyone had a problem similar to this? How did you solve it?
Last edit: 24 Mar 2013 19:00 by staniel.
- Nebr_Rex
- Thank you received: 300
24 Mar 2013 20:41 #578624
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ750L leaking oil cooler lines at pan
Pics.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- staniel
24 Mar 2013 20:56 - 24 Mar 2013 20:59 #578627
by staniel
Replied by staniel on topic KZ750L leaking oil cooler lines at pan
Sorry! I totally noobed.
Droplets of oil form on the bottom of the bracket holding the lower channel to the oil pan. I wiped it off pretty good and rode it around - the leak is way less bad now with the Permatex. I'm thinking I'll ride it like this a while, order the 12mm O-Rings and, if it comes back I'll mix a more thorough cleaning into my next oil change.
I still could use some advice here. I'm also worried about stripping these threads.
Attachment IMG_20130324_164304.jpg not found
Attachment IMG_20130324_164552.jpg not found
Last edit: 24 Mar 2013 20:59 by staniel.
