Kawasaki 1979 KZ750t
- kledda970
23 Mar 2013 19:38 #578372
by kledda970
Kawasaki 1979 KZ750t was created by kledda970
I have a kawasaki 1979 kz750 kickstart. it started when i bought it, everything was working fine, when i got it home and tried to start it, it wouldn't start. i bought starter fluid, used it, but the battery was dead during that time, still wasn't starting. what do i need to do?
- Thank you received: 2829
24 Mar 2013 00:52 - 24 Mar 2013 00:53 #578454
by 650ed
Replied by 650ed on topic Kawasaki 1979 KZ750t
I would start by buying a new battery. Charge the new one with a LOW amperage (2 amp or lower) charger. Do NOT try to start the bike by jumping it from a running vehicle as that can damage the electrical system. Also, buy a Kawasaki Service Manual. They are available on eBay. Be sure to get one for your bike's exact year / model. In it you will find instructions on troubleshooting the bike's charging system which may help. Ed
Last edit: 24 Mar 2013 00:53 by 650ed.
The following user(s) said Thank You: kledda970
- Topper
- Thank you received: 133
24 Mar 2013 09:28 #578484
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Replied by Topper on topic Kawasaki 1979 KZ750t
When you say it started when you bought it, you mean the electric or kick start?
Ed's right, start with the battery. You can take it to an auto parts store and have it tested before you decide whether to buy a new one.
What's it doing when you try to start it?
1979 KZ750 Twin
- steell
24 Mar 2013 14:31 #578527
by steell
Replied by steell on topic Kawasaki 1979 KZ750t
Make sure the master switch on the right handlebar is in the "Run" position.
Do not hold the clutch in when attempting to kick start.
Do not touch the throttle, just make sure the choke is on (left side of carbs)
If that don't solve your problem there's a checklist we'll follow to diagnose it.
- kledda970
27 Mar 2013 19:33 #579153
by kledda970
Replied by kledda970 on topic Kawasaki 1979 KZ750t
When i bought it, it kickstarted after like 2-3 kicks. and after it is warmed up, it's able to eletric start.
- kledda970
27 Mar 2013 19:38 #579154
by kledda970
I did all of that, i even put the gas lever ON
- Topper
27 Mar 2013 20:11 #579160
by Topper
1979 KZ750 Twin
Start with the battery. Take it to an auto parts store and have them test it.
1979 KZ750 Twin
- kledda970
28 Mar 2013 02:35 #579220
by kledda970
and every time i try to kick start, i smell the gas,it sounds like it wants to start but it just doesnt, i think some times i here the exhaust sounding like it wants to start
