- Thank you received: 64
GPZ oil pan into KZ750 H LTD
- undiablo
19 Mar 2013 20:56 - 19 Mar 2013 21:01 #577747
by undiablo
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
GPZ oil pan into KZ750 H LTD was created by undiablo
SORRY FOR THE DOUBLE POST- PLEASE DELETE
Hi guys!
It is not finished yet, but I took some pictures of the mod I´m making to my KZ750 H LTD.
I am installing, the next winter, a GPZ 750 oil pan (needs a paint job first). I welded the hose connectors to a little piece of metal, wich previously I cut my self and made a circular o`ring cavity. Put some Viton o`rings there, I hope it doesn`t drip oil in the future. Black color was done by heating the metal piece and soaking in used burnt oil.
The oil pan did not have the oil level sensor, so I made an aluminum cap with and o`ring for sealling purposes... may be in the future I could install a temp sensor...
The coller (no pictures yet) is an used one from a Harley Davidson Shovelhead, I am also including the HD thermostat.
What do you think till now?
Hi guys!
Attachment not found
Last edit: 19 Mar 2013 21:01 by undiablo.
