GPZ oil pan into KZ750 H LTD
- undiablo
19 Mar 2013 20:28
Hi guys!
It is not finished yet, but I took some pictures of the mod I´m making to my KZ750 H LTD.
I am installing, the next winter, a GPZ 750 oil pan (needs a paint job first). I welded the hose connectors to a little piece of metal, wich previously I cut my self and made a circular o`ring cavity. Put some Viton o`rings there, I hope it doesn`t drip oil in the future. Black color was done by heating the metal piece and soaking in used burnt oil.
The oil pan did not have the oil level sensor, so I made an aluminum cap with and o`ring for sealling purposes... may be in the future I could install a temp sensor...
The coller (no pictures yet) is an used one from a Harley Davidson Shovelhead, I am also including the HD thermostat.
What do you think till now?
Attachment reformaradiadordeaceite1.jpg not found
Attachment reformaradiadordeaceite2.jpg not found
Attachment reformaradiadordeaceite3.jpg not found
Attachment reformaradiadordeaceite4.jpg not found
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- Nebr_Rex
Re: GPZ oil pan into KZ750 H LTD
19 Mar 2013 20:54
Nice job.
You could not locate a GPZ oil cooler also?
A little trick you might be interested in.
Add a washer or two to he relief valve that is in the line right before your cooler fittings
Be careful, there is a check ball with a spring with some pressure.
I used a Phillips screw driver pushing down in the center of the washer to hold the spring while I removed the snap ring.
Add a washers to double or triple the original and reassemble.
This will increase oil pressure.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: undiablo
- undiablo
19 Mar 2013 21:02 - 19 Mar 2013 21:04
Thanks for the trick!
It is not dangeorus to increase the oil pressure?
I was searching for a GPZ oil coller, but price was a bit high to me. I bought the HD shovelhead cooler and thermostat for USD 2 plus shipping. :whistle:
Last edit: 19 Mar 2013 21:04 by undiablo.
- baldy110
19 Mar 2013 21:54
There is no reason to raise the oil pressure in a stock motor. Your setup looks nice it should work fine. A GPZ750 oil cooler and lines makes a nice clean install if you can find one. Here is one on my KZ650.
- Nebr_Rex
19 Mar 2013 22:16undiablo wrote: Thanks for the trick!
On an engine with some wear on the bearings it will not hurt but help.
On a stock low mileage engine there is no need for it.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- staniel
06 Apr 2013 15:17
You guys have these apart, so you'll be better equipped to answer my question:
I keep getting an oil leak out of the cooler fittings. I replaced the o-rings and still it leaks slightly. I think the bottom right (viewed from front wheel) threads are stripping out - would there be any reason that oil would leak through that hole? Would there be a problem in drilling it out and cutting bigger threads?
Sorry to hijack your thread.
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
- baldy110
06 Apr 2013 22:57
No the bolt holes are blind holes, they will not leak. If you have a stripped out bolt hole then it will never seal. I would not go up to a larger bolt. Get it helicoiled or similar.
- donconcha
- Yop
04 Dec 2016 07:16
i Have a KZ750 LTD H1 .
i'm looking for the pan and the cooler but i can't find this part:
where do you get it?
Do you have to do something extra to make all the system fit?
KZ 750 LTD H1 - 80
ZR 550 Zephyr 91
ZR 550 Zephyr 91
04 Dec 2016 09:46Better try again on the link. It's dead.
05 Dec 2016 05:46 - 05 Dec 2016 06:14i Have a KZ750 LTD H1 . .... i'm looking for the pan and the cooler but i can't find this part (oil cooler fitting):
From the topic post I think he made that fitting.
ps: you might be able to use an oil cooler & oil pan from a ZR750 (ZR7 or ZR7S from around 1999-2005). not sure.??? ... From the diagrams at partzilla the ZR7s uses the same oil pan gasket.
Last edit: 05 Dec 2016 06:14 by martin_csr.
The following user(s) said Thank You: Nessism, donconcha
05 Dec 2016 07:56
My 750E uses a ZR7 oil pan and a cooler from a KZ700 (same as the '82 GPz750 and later 750 L model bikes - same unit baldy110 used). It's pretty much a straight bolt on other than I had to fab up some mounts for the cooler which was easy enough. Be warned that a larger cooler such as one from a ZR7 will not fit because of the tach cable.
- baldy110
05 Dec 2016 08:40
The GPZ750 pan, oil cooler and lines will pretty much bolt right on. The only fabbing I had t do was weld on tabs for the oil cooler but you can probably figure something else out if you cannot weld it.
