clean/kleen air emissions system
- donthaveakawman
16 Mar 2013 22:44
curious as to where the vacuum hoses go at this point. why link 2 cylinders together, won't that cause a slight indifference in the synchronization? is is possible to use 1 vacuum hose? I would like to keep it as it produces more factory hp on the years that have it.
- Lorcan
- Speed Loony
Re: clean/kleen air emissions system
17 Mar 2013 06:03
UK bikes don't have it and they make the same power, it's nothing to do with power output.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- Powerstroke_fan
17 Mar 2013 09:29
The emission system is just what it says, It helps reduce exhaust emissions by rerouting the crankcase vent into the motor to be burnt off.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
