- Thank you received: 299
ignition switch electrical
- donthaveakawman
- Visitor
16 Mar 2013 19:09 #577245
by donthaveakawman
ignition switch electrical was created by donthaveakawman
see what I get for buying used electronic devices on the internet. my ignition switch does not have power going to all the wires when it is on. is this a problem and should I get a new one for my 80 kz750h?
- wireman
16 Mar 2013 19:17 #577246
by wireman
Replied by wireman on topic ignition switch electrical
Does it have power going to what you need power to,whats missing?
- 4TheKZ1000
- Visitor
16 Mar 2013 19:44 - 16 Mar 2013 19:45 #577252
by 4TheKZ1000
Replied by 4TheKZ1000 on topic ignition switch electrical
1.How many wires are going in and are going out.
2.What colors are the wires going in and going out.
3.This will determin if you have the version you might need.
Last edit: 16 Mar 2013 19:45 by 4TheKZ1000.
- donthaveakawman
- Visitor
16 Mar 2013 20:57 #577272
by donthaveakawman
Replied by donthaveakawman on topic ignition switch electrical
about 6 wires in the connector 2 weren't getting volts I spliced one for the taillight and the dash lights don't work but are getting juice to the wires I think. maybe the bulbs.
- donthaveakawman
- Visitor
19 Mar 2013 00:44 - 19 Mar 2013 04:32 #577639
by donthaveakawman
oh there was just a bunch of crud on the metal parts inside it it is all better now. while I had it apart I took the blinker indicator lights and stuck them into the speedometer-speedo lights, :woohoo:
Last edit: 19 Mar 2013 04:32 by donthaveakawman. Reason: mechanical malpractice
