Relieved
  • Andy Lishious
  • Andy Lishious 's Avatar Topic Author
Relieved
16 Mar 2013 15:01
#577217
Ok so heres the low down... a few days ago i was riding my kz tearin it up the norm and all of a sudden i hear this funky noise. Sounded like a valve sunk and my piston was banging into it i thought i blew it up. I got the bike home ripped it all apart and what i found was the chock plate screw came loose and got sucked in. It banged up my piston and camber the damage isn't bad the cylinder walls aren't even scratched It's all rebuildable That's why im relieved. So anyways im in need of just a head gasket i don't need the complete gasket set. Would anyone know where to get just the head gasket. I can't find anything online. Thanks Andy...
1981 Kawasaki kz750 E 160 pound rider
1973 Bultaco Alpina 250
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
Re: Relieved
16 Mar 2013 15:04
#577218
Z-1 Enterprises
Redline Cycle
Pitstop Performance
Dealer
The following user(s) said Thank You: Andy Lishious
  • Andy Lishious
Re: Relieved
16 Mar 2013 15:05
#577219
Thanks dude i totally forgot about z1.
  • Andy Lishious
Re: Relieved
16 Mar 2013 15:17
#577220
Note to self.. use lock tight on the chock plate screws next carb rebuild...
  • donthaveakawman
  • donthaveakawman's Avatar
Re: Relieved
16 Mar 2013 17:52
#577233
be wary of z1 they sold me a tiny fuel filter that I don't like.
  • wireman
  • wireman's Avatar
Re: Relieved
16 Mar 2013 18:01
#577236
donthaveakawman wrote: be wary of z1 they sold me a tiny fuel filter that I don't like.
Attachment caution.jpg not found
:woohoo:
  • mopguy
  • mopguy's Avatar
Re: Relieved
16 Mar 2013 18:59
#577243
What carburetors are you talking? I rebiult a set for the 81 KZ1000, I think they are 34mm Mikunis and I dont remember needing to put locktite on the choke, I hope I dont have to. As for Z1 I never had a problems with them and I find them very helpful and courteous, and by the way if you are reading(Donthaveakawman) I do run the same filters on all my bikes and they do work very well.
  • Andy Lishious
Re: Relieved
16 Mar 2013 19:28
#577249
I have the cv 34's I take them all off the racks and ultra sonic clean them before i put the bike away in the fall. To get the carbs off you need to take all 8 screws out and the plates slide out and the carbs come right apart. Takes awhile.
  • Andy Lishious
Re: Relieved
16 Mar 2013 19:30
#577250
I'm looking my my factory service Manuel and they want you to buy new screws and crimp the back with special pliers.
  • Andy Lishious
Re: Relieved
16 Mar 2013 19:31
#577251
pg 49
  • mopguy
  • mopguy's Avatar
Re: Relieved
16 Mar 2013 19:49
#577253
Thanks.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Relieved
16 Mar 2013 19:53
#577255
I run those filters. I personally like them. There small and easy to fit inline. I ran my 1075 kit with 36 flatslides and never had a problem with fuel starvation. I will be running them on my 1327. hopefully they will still keep up.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
