'79 KZ1000 Mk2 Crankcase with '83 z1000-j3 top
  • Mk2Rookie
  • Mk2Rookie's Avatar Topic Author
16 Mar 2013 14:18
#577212
Hi! I'm wondering if it can be done;
I would like a kickstarter on my '83 z1000-j3, and i got a spare engine from a mk2 '79 lying around.
So my question is, can i use the mk2 (1015cc motor) crankcase with j3 (998cc motor) crankshaft, (clutch maybe), cylinder & top ?
Simon
  • zed1015
  • zed1015's Avatar
Re: '79 KZ1000 Mk2 Crankcase with '83 z1000-j3 top
16 Mar 2013 16:32
#577227
Not a simple bolt on conversion.
Some machining required.
  • LarryC
  • LarryC's Avatar
16 Mar 2013 17:09
#577230
Lot of work just for a kick starter.
Larry C.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
16 Mar 2013 20:02
#577258
You can run a j model head on a kz bottom end and jugs. but i believe the bolt patterns are diffrent on the engine mounts. If you run a 81 j model head you can use oem tach cable. the 82 and 83 dont have the gear on the cam and the hole in the head.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • MFolks
  • MFolks's Avatar
16 Mar 2013 21:06
#577276
