carb cleaner in oil
- donthaveakawman
carb cleaner in oil
16 Mar 2013 03:35
during my valve adjustment I sprayed a bunch of carb cleaner in my spark plug holes and I am pretty sure some if not all ended up in the oil via blowby. I changed my oil at the beginning of this year with a k&n filter. 3 months or 3000 miles would tell me that i should change it.
is the carb cleaner a problem?
- Lorcan
- Speed Loony
Re: carb cleaner in oil
16 Mar 2013 07:02
Not if you use it for cleaning carbs.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- bountyhunter
16 Mar 2013 15:54I've done the same on cars to clear heavy carbon out of the throttle body and cylinder. I always put in fresh oil after doing it to be safe.donthaveakawman wrote: during my valve adjustment I sprayed a bunch of carb cleaner in my spark plug holes and I am pretty sure some if not all ended up in the oil via blowby. I changed my oil at the beginning of this year with a k&n filter. 3 months or 3000 miles would tell me that i should change it.
- donthaveakawman
16 Mar 2013 17:42
go figure it sounds like it is having a hard time.
